Shockworks Presents Round 9 - Sandown Raceway 1st Oct | Grand Final Day
1 minute ago, acsplit said:
Next 10 days or so, what would you like to know?
Cheers. I've got an older helmet with the date worn off and scrutineers are sometimes a little iffy about it.
I know that there's recent rule changes for fire extinguisher dates, what's the go with helmets?
Let me get back to you
  • Like 1
Got my spot. First time around sandown since 2009 or so when I was 19! Apart from that one drift day I went to, but we don't talk about that..
Thanks man. If I need to get a new one the 2016 Bell Qualifier looks decent, it's ECE 22.05 Standard Certified.
The CAMS Schedule D lists under Level A Standard 'E22 (with 03, 04 or 05 amendments)' – can anyone please confirm if this is the same?
Will get some confirmation from CAMS for you.
Ok discount entries sold out!
Get your entry in asap as the day is capped at 60 which is half the normal capacity.
  • Like 1
Ok guys here is the info on helmets and fire extinguishers
Most helmets from your local motorbike shop will pass the requirement. Which is it must have the AS/NZS 1698 sticker or greater.
However you get what you pay for, so the cheaper helmets are heavier, bulkier and hotter. I'd suggest something in $200 range, as that provides good overall value.
The fire extinguisher must be 900g or larger with a standards sticker of as1841 (not as1841.2). Which you can get from autobarn or supercheap, make sure it has a metal bracket. The date stamped on the bottle is only valid for 3 years, so get one with this years date on it. You need to 'bolt' it to the car which you can grab from here. This bracket bolts straight to the seat, without the need for drilling or cutting
  • Like 1
Thanks! So no date requirement on the helmet?
No, however if you feel like your helmet could be borderline unsafe due to it's age (or if it has ever been in an impact (including dropping it on the ground)) then personally I highly recommend getting yourself a new one.
It's amazing how many people try to sneak through with dodgy things, when the restrictions are there for their own safety... The CAMS scrutineers have seen it all, so if in doubt, don't risk it.
  • Like 1
Fair enough. I know that a motorcycle helmet is the easiest option but where do people go for entry level Hans enabled ones in Melbourne?
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
