Hi all, had the car couple months. Making 300kw. Overheating on freeway but cooled down in traffic then would rise up slowly. Drained coolant and replaced thermostat. Heater wasn't working when I got the car. Went to bleed via x2 head bleed screws, rear one bleed out but front one had nothing come out as car continued to overheat. Any ideas on the matter?
https://www.sau.com.au/forums/topic/466207-r34-overheating/
First try bleeding the system properly ( with heater set to full on - check that the heater is still connected - some people just block off the hoses when the element inside the car starts leaking). Clear the blocked bleed screw. Perhaps go the whole hog and jack up the front and stick a cut off plastic bottle in the radiator filler and fill slowly as you run the engine from cold.
Your cooling system could be full of rust and scale. Did you drop the bottom hose to drain it? What was the stuff like that came out? Try a reverse flush with a hose for both the block and the radiator. Does the radiator look OEM? If so it is likely due for cleaning or replacement. While at the radiator shop get it pressure tested for leaks. Get a new radiator cap.
https://www.sau.com.au/forums/topic/466207-r34-overheating/#findComment-7765337
Today I put in a triple core radiator, both bleed points bleed out with coolant, heater got abit hot. And temp sat in middle. Took it for a 20 min drive temp stayed fine until pulled into driveway. Rises till about 3/4 then we cracked off the top bleed screws again alittle air came out and temp dropped alittle but still sat just under 3/4. Definatetly a lot better than before but still rises slowly. Bleed with car jacked up plus coke bottle so done the right things
https://www.sau.com.au/forums/topic/466207-r34-overheating/#findComment-7765409
Is your stock gauge reading 3/4 or do you have an aftermarket gauge in which case what does it read in deg C ? Doesn't sound to me like its overheating now..
https://www.sau.com.au/forums/topic/466207-r34-overheating/#findComment-7765545
It's still a stock gauge. Doesn't tell me in deg c. It doesn't overheat for awhile I done about 5km of driving in traffic stayed about half way. As I got into the driveway slowly started to rise up again till 3/4. Top hose was hot but the bottom hose was luke warmish slightly hot if that makes sence, the heater was abit hotter but still not crash hot as what it should be, and now I got the big triple core radiator on it, new thermostat and new temp switch. Definatetly a lot better than the old radiator it would of just overheated in the driveway but it's got me puzzled
https://www.sau.com.au/forums/topic/466207-r34-overheating/#findComment-7767050
On 13 August 2016 at 9:59 AM, MrStabby said:
Heating up when stationary point to the fan. Is the fan clutch tired? Could be you had two problems and you've only fixed one.
Any idea on how to properly test the fan. Whenever cars on seems to spin ok
https://www.sau.com.au/forums/topic/466207-r34-overheating/#findComment-7767052
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
