so you going to cut and weld metal in between the arm somewhere to extend it if I read that right ? or you going to buy proper adjustable LCA's?
Just letting you know s14/ r33 LCA's are longer than R32 by 10 - 15mm (cant remember) if that's enough and easier for you.
If you are going to cut and weld, you'll need to box out (brace) the underneath of the arm with a couple of bits of sheet metal welded across it to give it some support
Either way... with you moving everything out further you will need camber arms, tie rods etc etc to match the length ...so longer ones which ill no doubt have to be adjustable ones
also depending on your rim / tyre combo it may now scrub front bar or rear of tub as it carrys a new arch
Edited by bcozican
