Hi All,
Hoping for some advice as I have lost hope after about 30mins lol
So the issue developed about 2 weeks ago when I moved it to wash.
Moving in / out the driveway and sitting idle I could hear a very low constant beep noise, at first I thought it was the turbo timer but nope it's def not that.
I have stuck my head all through out the dash around the drivers side, the best location is above the left knee around the steering column but I still can't locate it. It's a very low pitched beep and if you were sitting in the passenger seat you probably wouldn't hear it.
It also was not present prior to hearing it.
Any help is appreciated.
https://www.sau.com.au/forums/topic/466229-low-faint-beeping-noise-r33-s2/
Check for a small speaker looking unit behind the drivers side door card
other thought was an aftermarket alarm with a dead/dying roll of watch batteries
perhaps even a hidden turbo timer behind the dash
  • Like 1
Depending on the sound it could be some sort of earthing issue. I know that one of my old cars made a low pitch whine when it was started. It varied with the RPM of the engine.
One thing I can suggest is to double check your terminals on the battery (assuming you don't have two). Make sure they are super clean and tight. If your car has a separate earthing point to the chassis (normally located either at the front of the car or near the strut towers), check the earth. If this is in poor shape you can introduce all sorts of odd harmonics.
The other sound that it could be is a dying capacitor. They make a funny squealing sound when they are dying. Do you have any electronics (PCBs) mounted in the area that could be the source?
^^^ That said if you are absolutely sure this is a beep and not some spurious noise, you need to look for electronic boards. You will most likely be hearing a piezo speaker. These are generally smaller than a 5 cent piece and are mounted within electronics, so are hard to hear.
Most smart (read: well designed) items will start to beep if the board detects a lack of power.
Quote
This is most likely the reason, most of the circuit will be receiving 12V (or thereabouts) from the car and will operate fine, but the backup battery (normally a lithium watch or button battery) may run on a different area of the board with it's own power sense circuit. When the power drops the circuit will move from it's normal mode of operation, to a circuit that include the speaker, thereby creating the beep.
I'm not familiar with enough of the R33 electronics or any of the aftermarket items to know what it could be, but you may find it's as silly as the clock or radio in the car.
I'd suggest (if it bothers you enough) to pull off any trim in the area and try to isolate the sound. It could be coming from deep within your dash.
Yes that's the stumping part.
Only when the car is on it beeps.
It's comes from around the steering column.
I'm going to spend some more time on it as I noticed the greddy control boxes are shoved around in there ( I assume control boxes for boost and oil temp gauge ) I seem to have a sneaky suspicion it may be either of them cause that's the only items in the vicinity.
Also ripped out the turbo timer and still doing it.
  • 3 months later...
  • 7 months later...
  • 1 year later...
Any solution to this ? I have similar situation in my skyline V35, 3 beeps at ~1 every 2 sec interval even without keys inserted, lower than the sound it makes when I leave the keys in with door open. Does not make the beep sound when I have car running though.
Edited by kool
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
