Im am selling my R34 due to lack of use ,2000km in the last 2 years .I purchased the car from a mature owner who owned the car for 7 years he bought the car as a weekender and left it basically stock . I flew to Melbourne to purchase the car and it was immaculate ,drove it home and added the following .High flowed Hypergear Turbo ,750 ID injectors ,Power FC with Hand Controller ,Turbo Smart electronic boost controller ,ACI Hi Performance Clutch ,Blitz Radiator with new thermostat and hoses ,new Nissan OEM Coil Packs ,New Nissan wiring loom,Z32 AFM ,HKS strut tower brace ,Walbro 460 fuel pump,new Tie rod ends ,Nolethane Castor bushes ,Hi flow dump and cat ,HKS Hyper Street 3 coil overs base height and dampening adjustable ,professionally set up ,New Hankook Ventus R-S3 ,Hel Braided brake lines, DBA slotted and cross drilled rotors ,I think we put EBC green pads in ,Turbo Timer ,SAAS Velour Steering wheel ,Car is tuned for E85 Fuel it made 306kw low boost and 330 KW high boost .the car is very fast !!!.Clarion 305 BT head unit and Vibe slick component speakers .Everything is in good condition and works ..All fluids changed with Synthetic fluids ,gear box , engine ,diff , gear box etc ,engine oil changed every 1000km .The performance shop was given the brief if anything needs replacing replace it compression and leak down was all very good .Block was flushed with liquid intelligence and sealed with the same ,currently running penrite coolant and Lucas water wetter .I remover the rear spolier and painted the boot with plasti dip white / pearl .No trades or swaps i have got too much stuff .No messages from oil rigs off shore or offers of credit card payment and your mate picks it up ,Gary 0400796009  $22,900 cp4764144684714514877.jpg?height=700&asp
Edited by thewayweroll
forgot price
https://www.sau.com.au/forums/topic/466244-r34-gtt/
  • 2 months later...
  • 4 months later...
  • 6 months later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
