<Cool Story Hansel>
Of the 3 cheapy Pro-Sport gauges I have in my car, one is an exhaust pyrometer.  Probe is installed in a hole drilled in the exhaust housing.  I installed it years ago, and it has provided interesting information since.  But this week it paid back the purchase price and installation effort several fold.
The other day I booted the car out of a corner and at decent load&revs in 2nd gear the gauge went over the ~950°C alarm temperature I'd set and flashed red.  I went along fairly gently after that, but noticed that the exhaust temperature would climb a lot faster under any moderate load than it normally would.
So, theories started to multiply in my head.  Dead injector?  Soft fuel pump?  Thermocouple sheath finally burnt off an thermocouple junction exposed to full exhaust flow?
Had a look under the bonnet and the FPR sense hose was connected and there were no problems with the AFM hose clamps etc.  Thought I'd add the idea of a dying AFM to the list of theories.  Fuel pump seemed like the obvious one, seeing as it is a Bosch 040 that has been in the car for a loooooong time.
Slapped the car on the dyno just now.  Mixtures were perfect.  Well not perfect, but they certainly were not lean.  Under any real load it was better than 12:1.  Ran it up harder and under decent load it was pinging its tits off.  Quite nasty.  Had some fairly aggressive timing in a couple of areas of the map, but it didn't used to ping there.  So we pulled some timing out and silenced the pinging.  There does not seem to be anything else wrong with it.  Right at the top of the revs/load it is as rich as buggery - some power to be found there later, but we'll deal with that another time.
Result?  Can only really be a bad batch of fuel.  I filled the tank on Saturday at a different outlet to my usual 1 or 2 places.  Suffered the high exhaust temps on, maybe, Wednesday.  All the driving between filling up and that time was commuting to work and back in horror traffic so no opportunities to load up and get any warning.  Too coincidental to be a coincidence, for my liking anyway.
Anyway, the pinging was bad enough that if I had continued on blithely thrashing it (if the opportunity presented itself) with the stereo turned up I never would have heard anything and it could have cost me the engine.  I'm happy.
</CSH>
Edited by GTSBoy
  • Like 8
Yeah, obviously proper knock detection is the best way to deal with pinging issues.  But.... further information relevant to my case in particular.....the ECU is Nistuned, so it actually has a knock sensor and good knock logic that actually appears to work.  But it doesn't do enough.  A proper aftermarket ECU with the ability to get really brutal with chopping the timing back would be required.
We could tell that the ECU wasn't happy.  It was idling with 5 degrees of timing when we started!
The point of my post was just to point out that the pyrometer is a bloody good bit of gear to have on board.  It could have warned me of a dying fuel pump, but it turned out to warn me of something else.  Not bad in my books.
Nice one, thanks for sharing, great result!
I had a similar deal with my water temps at Sandown couple of weeks back, would have cooked it a lot worse if it wasn't for the nagging Defi alarm.
Also I often hear 'but you won't have time to look at gauges on the track', which is true – except for a quick glance on long straights. It's still much better than not knowing, and the alarms and max readings (checked after each session) are the real deal.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
