<Cool Story Hansel>
Of the 3 cheapy Pro-Sport gauges I have in my car, one is an exhaust pyrometer.  Probe is installed in a hole drilled in the exhaust housing.  I installed it years ago, and it has provided interesting information since.  But this week it paid back the purchase price and installation effort several fold.
The other day I booted the car out of a corner and at decent load&revs in 2nd gear the gauge went over the ~950°C alarm temperature I'd set and flashed red.  I went along fairly gently after that, but noticed that the exhaust temperature would climb a lot faster under any moderate load than it normally would.
So, theories started to multiply in my head.  Dead injector?  Soft fuel pump?  Thermocouple sheath finally burnt off an thermocouple junction exposed to full exhaust flow?
Had a look under the bonnet and the FPR sense hose was connected and there were no problems with the AFM hose clamps etc.  Thought I'd add the idea of a dying AFM to the list of theories.  Fuel pump seemed like the obvious one, seeing as it is a Bosch 040 that has been in the car for a loooooong time.
Slapped the car on the dyno just now.  Mixtures were perfect.  Well not perfect, but they certainly were not lean.  Under any real load it was better than 12:1.  Ran it up harder and under decent load it was pinging its tits off.  Quite nasty.  Had some fairly aggressive timing in a couple of areas of the map, but it didn't used to ping there.  So we pulled some timing out and silenced the pinging.  There does not seem to be anything else wrong with it.  Right at the top of the revs/load it is as rich as buggery - some power to be found there later, but we'll deal with that another time.
Result?  Can only really be a bad batch of fuel.  I filled the tank on Saturday at a different outlet to my usual 1 or 2 places.  Suffered the high exhaust temps on, maybe, Wednesday.  All the driving between filling up and that time was commuting to work and back in horror traffic so no opportunities to load up and get any warning.  Too coincidental to be a coincidence, for my liking anyway.
Anyway, the pinging was bad enough that if I had continued on blithely thrashing it (if the opportunity presented itself) with the stereo turned up I never would have heard anything and it could have cost me the engine.  I'm happy.
</CSH>
Edited by GTSBoy
  • Like 8
Yeah, obviously proper knock detection is the best way to deal with pinging issues.  But.... further information relevant to my case in particular.....the ECU is Nistuned, so it actually has a knock sensor and good knock logic that actually appears to work.  But it doesn't do enough.  A proper aftermarket ECU with the ability to get really brutal with chopping the timing back would be required.
We could tell that the ECU wasn't happy.  It was idling with 5 degrees of timing when we started!
The point of my post was just to point out that the pyrometer is a bloody good bit of gear to have on board.  It could have warned me of a dying fuel pump, but it turned out to warn me of something else.  Not bad in my books.
Nice one, thanks for sharing, great result!
I had a similar deal with my water temps at Sandown couple of weeks back, would have cooked it a lot worse if it wasn't for the nagging Defi alarm.
Also I often hear 'but you won't have time to look at gauges on the track', which is true – except for a quick glance on long straights. It's still much better than not knowing, and the alarms and max readings (checked after each session) are the real deal.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
