Hey guys
Probably been asked a few times but everything i find/get told is different to each other..
So i'm trying to find out what turbo is on my rb25det. In r32 skyline
When I purchased i was told it was 'highflowed'
Later discovered the car was running a nistune i got my curious and started pulling apart intake pipes, manifolds etc to find out whats been done.
Ok so ive been told its a 28/71...
But want more info/confirmation
Or someone i can take it to in Melbourne that could help
Cast in Front on turbo compressor:
GARRETT M24
Cast on turbo housing at the back:
HKS 064
On the center tag:
Top: GARRETT JAPAN
Ki 0216J
Bottom numbers:
446179-5032
Someone please help...
https://www.sau.com.au/forums/topic/466284-help-id-this-turbo/
Unfortunately i have no idea man..
I brought the car as stock rb25 with a highflowed turbo
Then discovered the Nistune and now turbo
If i put a stock ecu in, it throws a nock sensor code and idles extremely rough and rich
Nistune only runs 1 knock sensor and it idles and and drives very smoothly and it doesnt smell like it runs rich, yet to calculate fuel consumption
Will be getting it to a nistune tuner as soon as everything else is sorted
Probably an RB20 ECU that runs with the nistune and apparently most nistuned RB20 runs entirely on the knock map so the tuner copy the main fuel and ignition maps into the knock map and it runs normally. Mine is setup like that, it constantly runs on the knock map with or without the knock sensors plugged in, evenĀ with the 1M resistor shunt to ground to replace the knock sensor. The ECU doesn't throw any code but still runs only on the knock map.
What is your ECU reference ?
According to my notes 446179-0032 is a 56 compressor trim GT2871R cartridge .
From memory what you have on the cold side is an earlyĀ HKS type machined inlet shroud which they used on the RB six cylinder versions of theirĀ 2530Rs 2535Rs and 2540Rs . The GTRSs had aĀ unique port shrouded compressor housing on the RB versions and the four cylinder versions had a Nissan/Garrett style compressor housing . The RB version used a 52 compressor trim version of the 2871R . I think the 2530 cartridge number was 446179-0021 , the 2535 446179-0019 , and the 2540 446179-0018 . I think the GTRS cartridge is 446179-0067 .
To me it looks like someone had a HKS spec turbo and hi flowed it with a Garrett marketed 2871 56T cartridge .
A .
Edited by discopotato03
  • Like 1
Ɨ
Ɨ
