Hi All,
Just got back from Japan and bought a few to many nismo items I no longer want to keep. All items are new.
-Black nismo bomber jacket, size is 2xl but they are a small make. Nismo item no=KWA03 50F64  $200
-Nismo chronograph titanium watch. silver face.Item no=KWA205F10  $350
-Black messenger bag, 280x410x120mm, item no= KWA4050D60 $200
-Mixed items selling as a package. Small red/black shoulder bag, Compact towel,bottle holder towel, Large red bottle holder,premium plate key ring. $70
Pictures below
Location campbelltown.
0406 769 404
Thanks,
Alex
  • Like 1
https://www.sau.com.au/forums/topic/466286-nismo-merchandise/
  • 3 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
