Hi guys,
I have some gear for sale.
- All items are located in Georges Hall, Sydney (2199).
- Postage is paid by the buyer.
- NO paypal!!!
- Upon delivery, please inspect items and if they are not as I have described then please let me know. You have 7 days from date of delivery/pickup. This is a condition of sale. I am not interested in you coming back to me after 6 months!
- If you require further photo's I will gladly take more and send them to you.
1:
Item: Apexi power intake
Condition: Fine. used for approx 5000 kms. Wont be needing it due to going single turbo. There is a little bit of surface rust on the brackets but a quick sand and a paint will sort that out.
Price: $200
A29DB344-0B69-4354-9F5E-11A325D14EAA_zps
B56203EF-72D3-4298-BCEE-9D8E6C5FD383_zps
EC921DC3-9BCF-4557-A131-DA8ABC23506A_zps
2:
Item: Under boot surge tank. It was on my R33 GTR and holds 2 x 044's. I will throw in the pumps (2 of) however I don't know what sort of condition they are in. The Feed/Overflow and return bungs are -8.
Condition: It could do with a clean and a repaint.
Price: $200
B38E848B-DDBC-45EC-BEEE-8E30CF4D6F65_zps
8BA16E78-1A27-49BF-9126-8A5F2E883B91_zps
E28E64E0-A93E-4D1D-AA8D-96398A88F6D5_zps
3:
Item: HKS Twin Turbo hard piping kit. This goes from the back of both AFM's and deletes the stock rubber piping.
Condition: Fine. A quick polish and it will look good as new.
Price: $300
28DFC3A3-693E-409F-A58C-726849E7B14B_zps
4
Item: Hypertune airbox and Titanium lobster back intake pipe with K&N pod filter (RF 1015). This was made with a combination of a 6 boost exhaust manifold, Borg Warner EFR 8374 (9180 will fit also) and an R33 GTR.
Condition: Perfect. It was made and i've decided to change it. Engine has not run with this setup on it.
Price: $1,000
28C48F21-6CAB-4838-AE10-02452D0B6664_zps
This photo is of a mates car. Box is identical but he just had allow piping done. I have shown this photo as it gives a better indication of how it all sits.
4A2AA073-54A8-4AFB-BFC2-9E2F50350777_zps
5
Item: Nismo gearbox mount.
Condition: Fine. Used for approx 10,000 kms.
Price:$50
Price:FF22ED1E-35FF-4E5F-9798-D864FC0175CC_zps
92BD9A5F-A757-4A01-B289-C97EB5E47738_zps
6
Item: Haltech EGT sensors and bungs.
Condition: Brand new. One packet was opened for photo purposes only.
Price: $600
FE6A7E0D-85D3-4D80-855B-7DE9DBF6794E_zps
FC1C1675-C431-4CE1-AC12-BEBBF63D8300_zps
1EC7A066-BA6E-4F0D-B98A-EA797144B689_zps
Item: Holley Dominator 12-1800 fuel pump
Condition: Fine. It came off GTR NUR's R34 GTR. It was used for one dyno session and was in the car for approx 2 weeks. I would have used it but I changed how I wanted to layout the fuel system.
Price: $350
27D85DE6-CDA9-44AC-A2B7-6B002E66EA3B_zps
62AF46C6-3F90-4B55-B353-910C8C45D63C_zps
8
Item: Turbosmart FPR 2000
Condition: Fine. Came off my car in working condition.
Price: $200
00DBE98E-AF00-450C-A816-18DA2AF01FED_zps
DE9DAE7B-C8AF-4974-BB9A-23C8858A33F4_zps
7D2BE3AE-B7D5-47B0-924C-2EDD964EA4BA_zps
DE9E0BCE-3DE0-4038-B539-089BEF0B1A9D_zps
Cheers,
Paul.
  • Like 3
https://www.sau.com.au/forums/topic/466289-garage-sale/
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
