Been a long time lurker here but just joined recently just to get some thoughts & opinions.
So I'm currently in a long-standing dilemma, whether should I build an r32 with a jzx90 1jzgte or just get a toyota jzx100 chaser which has a newer engine. Main purpose will be a reliable daily and will have occasional track/drift days.
If you had the time and money, what would you rather pick between the 2?
Also has anyone done an r32 1jz here? What are your thoughts?
https://www.sau.com.au/forums/topic/466306-r32-1jz-or-jzx100-chaser/
2 hours ago, Cowboy1600 said:
Is it school holidays already?
That necessary?
I have no opinion on this. I do love cool conversions though. I reckon a nice R32 with a 1JZ might be cheaper than a JZX100.
  • Like 1
Wow thank you for all the responses guys ?
Ok, i guess the only unicorn is my daily beater honda hahaha. 1jz does sounds phenomenal.
Have already spoken to a few wreckers and only 1 is available to ship a bunch of jzx90/100 halfcuts, big nom noms!
Its such a challenge but it will be worth it in the end i suppose. Im pretty excited! I'll be posting a build thread in about a month or 2.
  • Like 1
After owning my modified BMW 335i for over 3 years, the Skyline is a phenomenal daily when it comes to servicing costs and repairs (anything 1/2 major breaks on the BMW is like over $1k for the parts and multiply this by 3-4 times if buying locally)...
So much so I parked the BMW for now (currently suffering from ABS failure, leaky turbo seals, adpative head light failure and some other random ECU error codes) and went back to driving the beater Skyline as a daily work horse =D
  • Like 1
The list of errors/faults on my BMW right now... :down:
14051626_10154322699882040_1727254749144294652_n.jpg.1f0dc7fa34d490329f5b4147b86c20d8.jpg
Basically a dead ABS control module causing all sorts of shenanigans, and water getting into one headlight (failed internal seal due to age) frying a control module that controls the fancy 'cornering' lights and a brand new ABS module is over $2k USD from US or about $4k locally from a indy shop for the part alone (and you still need to get it 'coded' with a proper BMW coding tool from dealership or indy shop even if you DIY the install)... :dry:
I must add that my Skyline also suffers from the same 'water getting into head light issue' but because there's no fancy electronic control modules to break there all I did to 'fix' was drill some 'drainage' holes on the bottom of the light assembly to let the water drain out... :cool:
Edited by Mayuri Krab
On 31 August 2016 at 10:58 AM, niZmO_Man said:
^ and that's why I don't understand why people say Skylines are "expensive" and "stuff breaks" all the time. :P
Bmws have always been known to be unreliable shit boxes though, in Germany they buy them cheap and run them into the ground but for some reason they have a prestige status over here
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
