Hey guys,
I've just been hit with confusion over whether or not my turbos are ball or bush bearing.
The 3 turbos in question are
HTA Forced Performance 3076
Garrett gt3071
Stock fg xr6 turbo
I was just working on my xr6t and noticed when I spin it the wheel spins for AGES (it is installed on the car)
Then I get my Gt3071 and it only spins for a few seconds, I also don't think it had an oil restrictor when it was onstalled so it looks like it is bush bearing, but then the plate on the turbo says 'Garrett 700177-5023' when I look this up it looks to be ball bearing..
My new turbo is a Forced Performance 3076 and the plate on it says 'Garrett 700177-5022s' i thought this would definitely be a ball bearing turbo but it still doesn't spin near as long as the xr6 turbo..
The 3071 and HTA3076 both aren't installed on the car so could this be a reason they are not spinning as freely as the xr6 turbo?
https://www.sau.com.au/forums/topic/466338-i-have-ball-bearing-turbos-right-s/
After watching this video
It would appear they are ball bearing, putting oil in helped a little but still didn't spin as long as my xr6t, maybe it is something to do with it being installed on the car and it was still hot...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
