Ok I'm starting this post to see what is working for everyone.
My new engine is a 3025 neo built engine and I want to maximize its performance.
Old system is a 3inch turbo back 100 cel cat straight through muffler.
Was thinking about doing a 4inch dump pipe to 3 inch from dump back.
https://www.sau.com.au/forums/topic/466345-exhaust-system-setups/
You don't need anything crazy if you venting gate to atmo and run no cat..
If you not..good luck with that .., just take of exhaust on dyno before you piss fart around remaking stuff
400 should be a walk in the park for a 3 inch exhaust..
cheers
darren
Edited by jet_r31
The smart* approach (fully fully custom) is to route the wastegate pipe back in behind the cat.  Face it, the gate is not open very much of the time on the street, therefore the vast majority of the time all the gas is going through the cat.  Then when you really need the gate to flow lots of gas, you're not also requiring the cat to flow lots of gas.  Win.  Was it dose pipe Johnny who's done basically this recently?
*Only smart until you actually do get some sort of EPA/police attention, in which case it's not actually legal.
Yes Johnny did this and ive copied plus merged it later for good measure ?
3 hours ago, lcxu105 said:
So a 3 1/2"dump 700mm lone back to a straight through 3"with 100 cel cat with 50mm wastegate merged back in the 3" pipe should be able to handle 420 to 450rwkw?
i had a 3.5 inch dump, then a 3 inch with a slight offset lukey and a resonator on my r31. It ran 141mph through the mufflers on 25psi with a auto
it was quiet exhaust but with a vented gate
My mate had same mufflers in his vl turbo( manual)  as he copied with a 3582 turbo on upper 27psi, but with a 3 inch dump..he ran 138mph (you work the power out out) on a 3582 1.06 turbo , he dropped the exhaust  at dump and it made 10rwkw difference...Had a vented gate
No meows..
It really really comes down to vented gate..if you don't vent it..good luck. You need a f**koff big exhaust. Just like a Gtr with the twins replaced with upgrades...
or perhaps merge it a long way back. But thats a p.i.t.a
honestly you just need to test it, as different mufflers and cats pose different restrictions..even in same sizing..
cheers
darren
  • Like 1
Interested to see what difference venting the gate to atmosphere would make with my set up. Currently running a 4" dump to the bellhousing and then 3" from there through a single round muffler after the diff. Single cam RB30 with a powerglide. Head is stock besides slightly oversize valves and a small 218 @ .050 wade cam. Making 396rwkw with a 1.06 gtx35 on 30psi. Basically stopped making decent gains in power with more boost and inlet temps rising quite fast. The gate plumbs back in maybe halfway down the dump pipe. Would it be much more efficient going to atmosphere as I presume a fair amount exhaust flow would be through the turbo at that boost level?
I didn't have a chance to dump the exhaust last time on the dyno to see if any gains were to be made but I guess the stock ports in the head would be holding things back a little also?
What fuel are you running? 30psi i would expect to see more hp than that
I wrote a big post and it didnt work. Cbf again
My mate morgz on ct ran 3 inch dump/exhaust plumbed back
With a 3582 with billet 67mm  comp 1.06
Went 10.20@140 -30psi-auto-450rwkw..made no more power
He unplumbed gate and it went straight to 40psi and maxed fuel system out in the midrange where peak torque is. Had to plumb it back..lol
So maybe worth a look
Cheers
Darren
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
