lachie.ga Posted August 18, 2016 Share Posted August 18, 2016 (edited) Hey guys, i recently changed the transmission on my r31. since doing this the car wont start at first i thought something wasnt plugged in so i dropped the trans and double checked and made sure of everything being plugged in. still no luck so i though it was the fuel, i added fuel and yet again no luck. the car had been on jack stands sitting at a funny angle with the engine being the lowest point of the car. before the trans got changes the car started first kick and never failed, i have no idea what the problem could be. Edited August 19, 2016 by lachie.ga get more attention from people Link to comment https://www.sau.com.au/forums/topic/466365-my-r31-skyline-wont-idle/ Share on other sites More sharing options...
89CAL Posted August 19, 2016 Share Posted August 19, 2016 Sounds like a neutral switch problem. Its a safety so the car wont start in anything buy park or neutral. Was it always neutral? If you have a diagram of what all your relays are then look at that and see if there is a neutral start relay. You can check if it clicks when you move in and out of neutralJust guessing. Cant remember if it stops the car cranking or just firing. Can you hear the injectors clicking when cranking? Have you checked for spark? 1 Link to comment https://www.sau.com.au/forums/topic/466365-my-r31-skyline-wont-idle/#findComment-7767920 Share on other sites More sharing options...
lachie.ga Posted August 19, 2016 Author Share Posted August 19, 2016 it starts and runss for about a second so it defiantly gets spark and cranks over. it just wont idle i dont know if it is because the fuel filter might be clogged with the fuel from the bottom of the fuel tank? Link to comment https://www.sau.com.au/forums/topic/466365-my-r31-skyline-wont-idle/#findComment-7767922 Share on other sites More sharing options...
89CAL Posted August 19, 2016 Share Posted August 19, 2016 Ahhhh ok. Sorry misunderstood your post Link to comment https://www.sau.com.au/forums/topic/466365-my-r31-skyline-wont-idle/#findComment-7767937 Share on other sites More sharing options...
lachie.ga Posted August 19, 2016 Author Share Posted August 19, 2016 all good mate Link to comment https://www.sau.com.au/forums/topic/466365-my-r31-skyline-wont-idle/#findComment-7767938 Share on other sites More sharing options...
