Hi all,
So about 15 months ago I bought an R33 GTST.
When I got it, changed all of the fluids and belts (including timing with the help of a qualified mechanic mate). It's pretty stock, stock ECU and turbo. It has an electronic boost controller and (I believe) a Z32 afm.
It was having misfiring issues and idling (cold and warm) so I changed the coilpacks, sparkplugs and cleaned the AAC valve, which solved the problem. It then started to be restricted at high RPM - it was a dirty fuel filter.
The car was usually garaged however I have now moved at it sits outside all the time. It has developed a cold starting problem which has been getting progressively worse.
The car will crank fine (doesn't seem to be battery) and will fire once or twice and then stall. If the key is held on it will struggle around 300-500rpm and MAYBE will catch and run. If the key isn't held it will take 4-5 goes to get it to crank and fire and not stall.
This only happens when the car is dead cold. After it has been run for any amount of time, (any more than say a minute) it will fire back up first time no troubles at all. It runs perfectly once it is started, boosts fine ect.
I looked around the forums and found a cold start valve being full of gunk, pulled it off and it was clean as a whistle. I thought it might've been fuel however there is no issues at all once it is started so I didn't think it would be the pump or filter.
Just looking for suggestions at the moment, don't want to go replacing things for no reason. Does anyone have any ideas? Cheers.
https://www.sau.com.au/forums/topic/466368-r33-cold-start-problem/
33s can not use a Z32 AFM with the stock computer, check the colour of the label if its Pink then that's stock, if its orange then that's a Z32.
Either way, connect the computer to a laptop via consult and see if it's throwing any codes, then go from there.
Edited by Missileman
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
