Hey guy another thread about gear oil
Every post i read turned into everyone saying each other is wrong with what oil to put in.
So it doesn't go into gear when cold unless i fight it
And it rarely crunches gear.
So reading the post everyone says use the following:
-Vmx-80
-Syntrans (i can only find syntrax?)
-redline shockproof (blue??)
Can i get a definitive answer please?
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/
Redline shockproof is somewhat of a bandaid solution to a gearbox that has sufficiently unhealthy synchros that they pretty much don't work.  Not the best solution, but compared to a complete rebuild, sometimes the best one available.  I used it in my RB25DET box after the transplant when it would not select any gear at all with the engine running (with conventional oil).  Instantly better.  Has been in there for years now, even though it has a reputation for not being the best thing to run long term.
Other gearbox oils are just gearbox oils.  Some a bit better than others.  Some offer the same rescue service that shockproof offers.  If your box refuses to engage gears when cold, I suspect your first port of call would be to try the best conventional oil and see if it helps, then be prepared to try the smurfs' blood.
  • Like 1
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768212
3 hours ago, Jonnoo said:
Syntrax $30p/L
Vmx-80&vmx-m $38 p/4L
Is syntrax really worth the money extra
Seems a small investment. What do you think you have in your box now that is different from the cheaper oil? I think you'll find Redline Shockproof is not cheap either.
  • Like 1
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768481
It wasn't about cheeping out, it was more about noticeable differences between the 'common oils' before i went with the redline. :)
Anyway its all done, i used syntrans
easy job, hardest part was getting the filler plug off.
Drained i recon just over 1.5 ltrs
Filthy oil had a bit of sludge
No big chunks of metal on the magnet
Filled about 2.4-2.5 L
Hopefully shes all good! If not its redline time! :)57b931782409e_ImageUploadedBySAUCommunit
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768483
The 2 bottles above is how much came out
I used those 2 plus half a third, but i also spilt some.
No idea where a liter would have disappeared to tho
Gear changes do feel smoother
No abnormal crunches (not that there ever was) but definitely smoother...
I wont know for sure until tomorrow morning.
I think the clutch is disengaging properly, it doesn't roll when on a flat surface, next job is to bleed the clutch, never know when it was last done.
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768493
2 hours ago, Jonnoo said:
I used syntrans
I know. I recommended Syntrax or Motul Gear but never mind. Do you in fact have any clutch pedal free play?
Anyway you may be right about the box. An RB20 box won't stand too much caning.
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768966
Unfortunately they only had 1L in stock! I did try for the syntrax though.
Not really free pay but if i rev the car the peddle goes soft i can feel it sort of go lower if my foots resting on it, if that makes sense?!?
Yeah behind the 25 i don't think itll have much left even if it was fine
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768970
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
