Brake master cylinder and brake booster questions (R34)
I've searched for these with no luck so here goes:
  1. Does anyone know where to get a BM50 brake master cylinder rebuild kit for the R34 GTT OEM BMC?
  2. Is the BM57 a plug-and-play upgrade over the BM50? Would I retain existing brake bias and ABS with it? The idea is to go bigger (front) brakes in the future so if upgrading BM57 is similar cost to rebuilding the BM50 that might be the go.
  3. Does anyone know if the R34 GT brake booster is the same as R34 GTT? The part numbers seem different but I'm not sure if the P/N is for the booster+master combo, and the GT master is definitely the smaller BM44.
Thanks guys.
  • Like 1
Have you tried Nissan for the rebuild kit? I put a BM57 in my S1 Stagea and retained the original brake booster.  I don't know if bias is different but I put a set of D2 330mm 8 pot brakes on the front and GTR 2 pot on rear and did not have any apparent problems with bias.
  • Like 2
Good idea, I'll give that a go.
Does your ABS work ok on gravel/wet with the bigger master?
I'm actually pretty keen on the 330mm rotor size so I could retain my 2 sets of 17" GTT stockies, both with decent tyres...
Yes still got ABS. I believe D2 brakes sold in Aus as K sport or suchlike. Duncan has a set on one or more of his cars. Or GTR Brembos are 324mm. You may need to check if stock GTT wheels will fit over. I have used 17in Rays and 18in Skyline wheels.
  • Like 2
Have you pulled your MC apart to see if it is badly scored etc? If not a rebuild kit should be fine.
If you do want a new one Just Jap seem to have them for 395
http://justjap.com/catalogsearch/result/?q=Brake+Master+Cylinder
Thanks mate. I haven't pulled it out yet as I'd prefer at least installing some new seals before putting it back together.
I reckon I'll start with bleeding the abs unit as per the above instructions to see if that improves it at all.
Has anyone heard of HFM or used their parts? Their BM57 alternative is a decent price, pic below: https://hfm.parts/shop/brakes/nissan-bm57-brake-master-cylinder-abs/
Looks like it's a Chinese re-manufacture of the original Nissan BM57: https://www.facebook.com/gktech/photos/a.479905785391677.98225.133362883379304/729676497081270/
Do not use hfm bmc. Im not sure if anyone has had success with one but a lot of people have had major issues. The only parts they sell that are any good are their brake calliper adapters for R33 and S15. Just about everything else is junk unfortunately. I recently bought some of their calliper adaptors but wasn't game on trying out their rotors. LOL.
  • Like 1
I rang Race Brakes, they don't have the rebuild kit but suggested testing the master cylinder first.
I've just done the following:
  1. Car off
  2. Pump brake several times, stiff pedal
  3. Put tape measure next to the pedal
  4. Apply consistent brake pressure
  5. Measure pedal drop
I did this for 30 sec (max attention span) and there was zero pedal drop, so it seems like the master seals ok?
EDIT: I also just watched some vids on vacuum assisted brake boosters. I've always had this thing where in traffic lights, applying the same pressure, the pedal drop slightly after a while. Understanding now a bit more how a brake booster works, this could be the engine idle revs increasing ever so slightly > more vacuum > more brake boost > increased drop for same pedal pressure. Does this make sense?
  1. Car off
Yep. To confirm try the brake pedal first thing in the morning before starting the engine. Hit it a few times to make sure there is no vacuum left,  pause,  and then push down on the pedal and see how it feels.
  • Like 1
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
