  • 1 month later...
  • 1 month later...
Finally i change my clutch to ATS Triple Carbon Spec I, with new clutch bearing, shaft seal and new 12.9 bolts for clutch pressure plate and 10.9 for gearbox & mount bar.
Working perfect, like stock normal daily car :D Sooo easy to drive but a little noise when pedal is down.
I make it in 6 hours on repair pit.
  • Like 2
  • 3 weeks later...
    • hi guyss! im new here so i want to ask all of you guys about the nissan RB20, i just swap my A31 Cefiro/Altima RB20e To RB20DET and got a problem with the engine bearings such as conrod etc. but i have a spare engine which is rb20e. is it possible to use parts from an rb20e block ? or is there any difference on internal of the engine beside the compression ratio? because if i cant use some of the parts from rb20e , want it or not i have to buy new specific only for rb20det . thanks guys i hope you guys can help me and tell me which parts is different:)
    • Buy some GKTech ones, with sphericals instead of rubber or poly, and enjoy the lower control arms going exclusively in the up-down direction, instead of the forewards-backwards direction that squishy bushes allow.
    • Upgrade your Skyline or Nissan JDM Vehicle with this fully restored set of OEM Nissan Skyline R32 wheels, perfect for collectors and enthusiasts. • Authentic JDM Factory Wheels • Includes genuine Nissan center caps • Size: 16x6.5J, Offset +40 (OEM spec) • Gunmetal Grey for a clean, factory fresh finish • Suitable for 1989–1994 Nissan Skyline R32 and other models with matching specs • Tyres: Mixed Bridgestone and Kenda tyres included looks to be at least 90% Thread • All Centre Caps Display The Year 1989  They maintain the iconic OEM look that R32 owners love. Whether you’re restoring your Skyline to factory spec or upgrading from aftermarket rims, these are a rare find in this condition. Price:$1400 located Western of Melbourne I can also arrange a courier Australia wide at the buyer’s expense if needed. Just send me a message
    • I agree, most likely a sensor issue. You didn't mention how it was running but above about 20:1 it won't run anyway
