I recently got a car imported from japan, when we got it the clutch was really sensitive and when you changed gears if will pull you back into the seat, now I have had the car for a couple months it doesn't do that anymore the gears are a lot smoother its more like a jolt then a pull.
8 hours ago, Trex said:
When you put in the clutch it would pull you into the seat? That defies the laws of physics haha
What do you mean exactly?
haha well when I release the clutch is used to have more of a kick to it, now its just shifts like an automatic you can't even feel it
  • 4 weeks later...
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
