Hey there,
I've being having a shit of a week dealing with this guy on ebay who sells aftermarket bars for R34's.
The front bar doesn't meet up with the bottom of the bonnet, however the seller says
"you can either modify your own car steel bar or get a gtr from nissan.  he probably tell you you will need the headlight support as well which you can also modify your own one to fit."
Can anyone give me help as to what me means by this? Would a front reo bar from a GTR help? or is there a bar that runs behind the overhanging piece?
I feel a bit silly for asking here but I can't go look at my own car because it's at the shop.
Thanks guys.
https://www.sau.com.au/forums/topic/466403-r34-aftermarket-bar-doesnt-fit/
2 hours ago, jmknights93 said:
Is that a genuine GTR bonnet?
Looks like a Z-tune replica bumper?
It's not genuine anything, turns out it's a fake copy of an eastbear kit.
The ebay listing said "East bear" in the title, but it's not genuine.
Heres the ebay page http://www.ebay.com.au/itm/172048552624?euid=f488992ae7db454a8ef4fb8dab37aa20&bu=44495797078&cp=1&sojTags=bu=bu
and I've attached a photo from it.
Just now, jmknights93 said:
Ah yeah, I've seen that eBay listing. I was very curious about fitment.
Shame about the poor fitment and poor support from seller.
I've ordered a GTR part that should run along the back of the top part of the bar, hopefully that pulls it up a bit.
I can't refund it because I don't have the original packaging to ship it back, If it doesnt work at all the GTR parts can be used for a genuine GTR conversion, but funds is an issue.
The original front bar got pretty badly damaged at Wakefield so I've had to order something in a hurry because this is my daily, but thats gone out the window now.
Thanks for your help.
lol screw that. just put the label directly on the bar and send it back.
Did it really cost you $1,300?!? Get your money back! You can get cheap replicas for a few hundred that will probably fit better.
  • Like 1
Well it's come to an end the GTR parts helped the bar out slightly, but the fitment is still pretty shithouse.
Anyone looking to buy a kit from this guy on ebay, "godsmind66should seriously reconsider.
Seller also sent me a bunch of text messages and called me a few times, but I didn't pick up.
Luckily I not much of a show car kinda guy, and if it can take me to a track i'll be happy with that, but sucks getting scammed.
On 9/5/2016 at 11:03 AM, Adz2332 said:
i know its far from ideal but to cover the bonnet and front bar gap would a bonnet lip help?
Yeah probably would, but I'm looking to getting a GTR reo bar and fenders and going via that route.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
