Here we have for sale parts off a R33 Gtr that was removed due to upgrades, was working at time of removal however has been sitting in a garage for a few years. Originally purchased these parts for a project car but have since changed mind. All parts are cash on pick in Sydney Northern suburb, can post at buyers expense. Any questions please contact me by PM.
Nismo R33 Gtr computer S1, part no: 23710 rpr31-11, increase boost and removes speed limiter I believe, specs say can make 400ps at engine. $200
R33 Nissan genuine CD/MD player made by clarion, part no: B8192-89900, was told working but have not tested. $50IMG_3372.thumb.JPG.17055db23330b78d298de8c9aeb2bbc7.JPG
R33/34 Gtr air box with Greddy air intake, air filter is old and dirty with a small corner missing, would recommend replace air filter. $100IMG_3378.thumb.JPG.cabf0f2b80b05008836044e9c9ed0455.JPG
R33/R34 Gtr air flow meters, again have not been tested. $60
R33 Gtr CAS, has not been tested, $50
R33 Gtr coil and harness, not tested, $50
R33 Gtr, Gts starter motor, part no: 23300-20P05, probably needs rebuild, $30
R33 Gtr fuel rail, $10
R33 Gtr gear shift surround, needs to be repainted, $10
Also have stock manifold and worn stock piston but not sure what they are worth
Edited by baicai
https://www.sau.com.au/forums/topic/466406-r33-gtr-parts-rb26-nismo/
  • 1 month later...
3 minutes ago, dunnman99 said:
Hello,
I would like to put my name on the air box...shipped to Alice Springs,NT.
Let me [email protected]
Thanks
Sorry mate, air box already sold.
Only thing left is cd/md player and gear surround.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
