  • 4 years later...
  • Replies 51
lol Sydneykid- you started the original thread years ago...
http://www.skylinesaustralia.com/forums/To...l&hl=towbar
and a few others:
http://www.skylinesaustralia.com/forums/in...t&p=4382443
The most common is a "max" (contact details in the 1st thread towards the end). It is rated to 2 tonne. Cost me approx $700 delivered + $150 installed, and it has towed my evo to interstate events without any drama's :P
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4573107
Here's mine.
Cut to expose the rails then side in box section. Bolt thru into the box section for a solid fit.
1500kg braked.
Job was ok as they should have sealed the exposed metal better, will sort that later.
I'm in New Zealand, cost $299 installed with wiring. I removed the rear bumper which saved a lot in labour.
Rhys
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4573186
1500kg tow bar on an M35??? thats very good!!
Yes more than enough for what I need.
I did have to mod the small plastic left and right trays where it shows the photo of the plate in the boot so they sit flat.
People love how neat it sits on the car. Just the tongue sticking out with no ugly bars hanging down.
My custom exhaust from turbo back is getting finished tomorrow so will post photos up later. Going for the 'Remus' look :P .
Rhys
Edited by StageaM35
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4573544
I'm thinking it would be handy to get one, too. Not so keen on hacking up my 260RS body kit for the tow ball though. I wonder if could hide the whole thing and just remove the lower 260RS add-on part of the rear bumper when I need to tow something..
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4574199
Just had a word with him.
$220 NZD for the towbar, no wiring/plug but can be supplied (It's about $20 for the plug and wiring but you guys could source that over there).
That's for an order of 5 towbars.
The more that are interested the better.
Shipping price I would have to get them to look into but the cost can be broken up between you guys.
Cheers,
Rhys
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4574680
i think im in! even if i only use it once, being able to tow something would be awesome!
I think I'm in too.
So $240NZD inc wiring.
So what would shipping be?
Since most of the guys here are in Sydney, am I (we) looking at more for Melbourne?
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4574896
shipping OS is shipping. i dont think the destination matters much. only the setup of his jig to make 5+ at once is worth his while.
anyway, Rhys if you dont mind looking into it, i believe you have 2 people already!
there are plenty of M35s on the forum also.
do you mind taking a picture of the outside of the car with the bumper on please, post-install?
and does your M35 have a standard rear bar or an Aero bar etc??
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4574928
Rhys
Yeah that looks good mate, more photos thanks, with bumper back on etc. Where abouts in NZ? Saw a silver one at hamilton nissan dealer recently that had tow bar, only time in nz so far. Also what have you done with original exhaust, i see you have the twin exit pipes on final muffler. My 250RS came with the big bore look but quiet end pipe, not a fan of that look and doesnt really suit it etc. Would like that twin pipe end mufflar.
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4575046
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
    • Set of R33 GTST Calipers, Rotors and Pads. Calipers just taken off my car, rebuilt about ~30,000km ago. Rotors have done about ~20,000km total since new. Pads have plenty of meat. One set is DBA XP (road, hills) and the other set is Forza FR6 (track) Still working perfectly, not rusted, or seized or whatever the hell that greets used brakes. All clips, bolts, retainers, slide pins etc included. Also have OEM handbrake shoes I can throw in there if you're doing a conversion. $650 for the lot, SE Suburbs Melboune/VIC
    • I feel I have covid right now. I spent the time between Dec 21 and Jan 31 pretty much working 16 hour days on the car after it got back from paint. It turns out you generate a long list of "things to do" while the car is off the road but functional. After going to visit my mate for a "Couple of hour job" doing the brakes, 3 full days later I got home There was more on the list, (it got added to while sleeping on couches) but as everything on the list got enthusiastically crossed out as it happened, I've actually forgotten what they were. From memory there were bushes that had to be pressed in and out, washer jets to fit, etc. Some Gregging highlights: 1) The panel shop covered up my washer jets and painted over it. Good job, I think. We had to drill the new bonnet to fit new ones, which was understandably extremely scary. 2) My handbrake on the RHS is f**ked. After never adjusting it forever and learning on the fly, this one is still on my to-do list. It tightens when you pull the lever, but at about 10% of the tension that the passenger side does. Thoughts on what causes this would be great. 3) Pouring an entire liter of brake fluid over the reservoir because I forgot how to use my pressure bleeder. DON'T PUT FLUID IN THE RESERVOIR. IT WORKS BY USING PRESSURIZED AIR NOT PRESSURIZED FLUID.   471907729_9242915229093447_2708910336906717367_n.mp4  I can confirm the vents work great though. 4) Some of the bodykit fixings were f**king awful. I'm talking screwed in with what was at most a 2mm screw, and could flap the kit around by hand. Too many others to mention. They came in, went out of my brain forced by other stupid tiny things that came up and "While the car is on the damn hoist we can fix them" which was a mission in and of itself, because the car has skirts and is thus a pain to put on hoists. Because we had to buff the windscreen to get rid of the overspray, I also had to very gently wash the car. The "Run 3 wires" task was to re-attempt another gregging thing which was: The LS1 ECU in Australia does not have oil pressure wiring because the Commodores do not have a 'real' oil pressure switch The Corvettes in the USA do have oil pressure wiring because Corvettes have a real oil pressure switch. The ECU is the same physical ECU. So what I could do is pull the ECU apart, run 3 more pins and run it to the OEM oil pressure ECU, and the ECU should do this. What actually happened is that Greg did this with some not-so-proper-wiring/connectors to the ECU pins which 'might?' be okay put the car back together, and then the fuel pump wouldn't prime. So you can imagine I immediately undid all this work, put the ECU back into it's original configuration, thought I'd do some more research about what connectors the LS1 Ecu actually uses... and try again later. Except still no fuel pump prime. After a lot of sadness and checking/double checking it turns out it was the relay in the boot that controls the fuel pump. All I did was switch the trigger wires and it worked fine. I looked at the relay and it was covered in bog dust and was unknown years old. It's since been replaced and working fine. After I got the actual connectors, and the wires were ran I gathered my strength and repinned the ECU and Voila! I apologize for these MMS  472164532_8829400773820369_5410969472548349643_n.mp4  And even via ODB2 on the headunit, woo. Now Torque Pro can raise hell on track if it gets too low. It has a wonderful EMERGENCY_DISTRESS_SINGAL style warning if it goes below a certain threshhold. 472585876_9345134268844369_146554337148747327_n.mp4 TLDR: Car great. HFM kit works. So much cleaning. Buy my old stuff. Thanks.
    • That's a hell of a question right there and so broad that you could get 100 different answers and have them all be correct.  To avoid me typing up a 2000 word thesis that doesn't answer your question, do you have specific things you are unsure of? Does the car currently handle in a way that you don't like? Or is it closer to, you think the car drives fine currently. But you'd like it to be better, but you don't know what that 'better' is or what that 'better' feels like?
