  • Replies 51
Shopping Trolley I'm in Christchurch and the muffler in my first photo was the stock one. The muffler in the new photos is part of the 3" custom exhaust system from turbo back. Bit loud and drones too much so will get a mid muffler put in to knock it right back. We weren't too sure how it would sound so started with a couple of rez and a rear muffler.
My M35 is just the standard kit. You should be able to see if there would be any problem from the photo's if you have an aero kit.
No photos when I took the rear bumper off but all that is there is the rear impact beam in place of the towbar.
$240NZD including wiring to hook up to your car just like the photo's. It doesn't include any tricky plugs that connects to the factory lighting of the cars rear lights, just the plug you see with the cable so if you want you can source the plug over there. It's a standard Narva trailer plug.
So shipping to Sydney? I can get a price sorted, just need to know how many are interested for size and weight etc?
Rhys
Edited by StageaM35
https://www.sau.com.au/forums/topic/46643-tow-bars/page/2/#findComment-4575206
that is a tidy install!!
me likey a lot. so put me down for one thanks, shipped to sydney.
PS nice exhaust
Will post a new thread with photos of the exhaust on the car. Still needs tweaking to suit my taste for exhaust note :) .
Went for a 'Remus' look :D .
https://www.sau.com.au/forums/topic/46643-tow-bars/page/2/#findComment-4575255
LOCAL UPDATE
There is a company in Leichardt, Sydney (Fast Fit) that has engineered a tow bar to fit the M35.
It is not a heavy duty tow bar and is rated about 1000kg (the women I spoke to was not 100% sure this was the right rating so I suspect it will be 1250kg as this is the rating of most normal towbars).
It is concealed behind the bumper and has a straight tongue. (sounds like the one from NZ)
Price quoted. $490 including fitting and wiring.
I think I will go with the local option.
Cheers
Andy
PS. Thanks for all the info Rhys
Edited by andy65b
https://www.sau.com.au/forums/topic/46643-tow-bars/page/2/#findComment-4577350
Rhys, what's the weight rating...looks like a neat setup....well done.
It's rated at 1500 kgs braked. They guy informed me that 'all our towbars are welded & manufactured by certified welders (NZ4711) and designed in accordance with manufacturers specifications'.
The towbar is painted not powder coated. The paint is satin black.
From the first photos I posted up you can see they design their towbars very well. They lap metal over main bar then weld it back onto the box section all around the top, back, sides and bottom. The tongue is lapped behined the main bar and welded around. Very strong.
Rhys
Edited by StageaM35
https://www.sau.com.au/forums/topic/46643-tow-bars/page/2/#findComment-4577853
LOCAL UPDATE
I have this bar fitted to my m35, Alex at Nagoya threw it in to sweeten the deal when I bought. It is a very simple setup, but just bolts thru the boot floor in the tyre well with some plates. Definitely not heavy duty, have been using without issue so far, but the unzud towbar is a much better proposition, imo.
https://www.sau.com.au/forums/topic/46643-tow-bars/page/2/#findComment-4597033
LOCAL UPDATE
Cheers
Andy
HEY ANDY,
any chance of pm me whith the details in leichhardt
cheers
damo
https://www.sau.com.au/forums/topic/46643-tow-bars/page/2/#findComment-4613199
  • 4 weeks later...
HEY ANDY,
cheers
damo
I got a chance to have a look at the tow bar from Fast Fit in Leichardt on Saturday.
The bar mounts across the back of the car inside the rear bumper and has a tongue that also mounts into the wheel well. So it has 3 key mounting points. Either side on the rails and into the wheel well. The only part you will see is the tongue that comes out through the rear bumper.
The work shop looked very good and the people very helpful. I will post some pics once installed this week.
Cheers
Andy
https://www.sau.com.au/forums/topic/46643-tow-bars/page/2/#findComment-4669934
Cheers
Andy
Did you get the load rating clarified?
https://www.sau.com.au/forums/topic/46643-tow-bars/page/2/#findComment-4669986
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
