Hi all,
I am in the process of trying to confirm the kms on an R33 GTR that I am interested in buying. The seller does not have any of the normal import documentation (auction sheets, de-registration cert or a Jevic Cert). Normally in my buying process this would be the end of my investigation on a car and I would move on. However, the seller seems to believe that the NSW RTA holds copies of this documentation when the car is registered for the first time.
So my question to you: Does the NSW RTA hold copies of the original import documents when a car is imported into NSW for the first time?
I personally can't see this as being the case, however i thought I would throw this question out to a wider audience, as maybe, just maybe, someone out there has had a similar experience and can confirm one way or the other.
I'm in Victoria so have no experience with the NSW RTA. I have emailed the NSW RTA asking these very questions, but if they are like VicRoads, I could be waiting a while for a response.
Any light people can shed on this would be greatly appreciated.
Ah, that's some very handy information. If i'm not mistaken the compliance shop should be on the sticker. So I should be able to back track these details if I put in the effort (which I'm starting to wonder about). I'll let you know what I come up with.
I can't say I have, I didn't know they existed. I will take a look into this. Thank you very much @Terry_GT-R34.
I'm still waiting to hear back from the NSW RTA (so at least they match VicRoads in that respect). I'll post up anything I hear back for future reference.
I have heard back from the NSW RTA via email:
Quote
Dear Mr. Wood
Thank you for your query.
The Roads and Maritime Services (RMS) receives all odometer information from third parties, such as from vehicle inspectors during 'pink slip' inspections, and from motor dealers during the process of purchasing and selling vehicles. The accuracy of odometer reading information depends on the accuracy of the information that is provided to the RMS, therefore the RMS cannot independently verify whether odometer readings are correct.
It is for these reasons that the RMS does not provide odometer reading information to the general public.
If you suspect the odometer may have been tampered with it is suggested that you contact NSW Fair Trading for further investigation.
So in summary, the NSW RTA will not release any details regarding an imports first odometer reading. So I think as mentioned by Terry above, the best bet will be to go with a Japanese History Check or Japanese Odometer Check.
I certainly am learning a lot about imports considering I don't own one yet. :)
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
