Hi all,
I am in the process of trying to confirm the kms on an R33 GTR that I am interested in buying. The seller does not have any of the normal import documentation (auction sheets, de-registration cert or a Jevic Cert). Normally in my buying process this would be the end of my investigation on a car and I would move on. However, the seller seems to believe that the NSW RTA holds copies of this documentation when the car is registered for the first time.
So my question to you: Does the NSW RTA hold copies of the original import documents when a car is imported into NSW for the first time?
I personally can't see this as being the case, however i thought I would throw this question out to a wider audience, as maybe, just maybe, someone out there has had a similar experience and can confirm one way or the other.
I'm in Victoria so have no experience with the NSW RTA. I have emailed the NSW RTA asking these very questions, but if they are like VicRoads, I could be waiting a while for a response.
Any light people can shed on this would be greatly appreciated.
Ah, that's some very handy information. If i'm not mistaken the compliance shop should be on the sticker. So I should be able to back track these details if I put in the effort (which I'm starting to wonder about). I'll let you know what I come up with.
I can't say I have, I didn't know they existed. I will take a look into this. Thank you very much @Terry_GT-R34.
I'm still waiting to hear back from the NSW RTA (so at least they match VicRoads in that respect). I'll post up anything I hear back for future reference.
I have heard back from the NSW RTA via email:
Quote
Dear Mr. Wood
Thank you for your query.
The Roads and Maritime Services (RMS) receives all odometer information from third parties, such as from vehicle inspectors during 'pink slip' inspections, and from motor dealers during the process of purchasing and selling vehicles. The accuracy of odometer reading information depends on the accuracy of the information that is provided to the RMS, therefore the RMS cannot independently verify whether odometer readings are correct.
It is for these reasons that the RMS does not provide odometer reading information to the general public.
If you suspect the odometer may have been tampered with it is suggested that you contact NSW Fair Trading for further investigation.
So in summary, the NSW RTA will not release any details regarding an imports first odometer reading. So I think as mentioned by Terry above, the best bet will be to go with a Japanese History Check or Japanese Odometer Check.
I certainly am learning a lot about imports considering I don't own one yet. :)
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
