always looking to go faster .:D
I pretty much know that the GTX2967R will spool the same as the GTX2867R being a better comp/turbine  wheel match with more power/ less heat on the hotside.
just would like to see a visual result somewhere
(wanting to keep the same .60 /.64 housings and not go to gt30 comp housings)
  • Like 1
https://www.sau.com.au/forums/topic/466451-gtx2967r-turbos/#findComment-7769511
Since you have comparatively more space under there than the 26, why not get some borg warner efr 6258's bolted up?
I mean, a bit extreme and requires lots of swapping of stuff but results may be more worth it?
https://www.sau.com.au/forums/topic/466451-gtx2967r-turbos/#findComment-7769578
2 hours ago, Stealth400 said:
Go for the GTX2871r faster spool loves boost as all GTX turbos do.
You want to run a 71 mm GTX front fan and have it squeezing out a 28 series peanut ass end with a small wheel?
Keep adding compressor, it's the answer to everything!
Whatever happened to air in AND out? Talk about a mismatch. Maybe just run GTX 2876's. Compressor map says yes, right?
  • Like 3
https://www.sau.com.au/forums/topic/466451-gtx2967r-turbos/#findComment-7770083
no cost of custom isn't worth it and space is a problem redesigning manifolds.
I'll stick to bolt on garrets ,happy with results so far .
https://www.sau.com.au/forums/topic/466451-gtx2967r-turbos/#findComment-7770778
