Parts still required below:
SEE PHOTOS BELOW:
Parts MUST be off a 1997 Series 2 R33 GTST Coupe unless otherwise stated in RED
My car details VIN 6U9000ECR33133971       Build Date 11/1997  40th Anniversary Turbo Automatic
**Don't bother offering me Series 1 parts OR if you don't know the difference between the two Series don't send messages trying to offload parts you can't sell**
As it seems a heap of people don't know which parts actually match** I'd like to keep the rebuild as close to original as possible so no swapping cosmetics etc
I already have a bonnet, rad support, front bar + front bar fog lights, radiator (buying new), rear lower control arms, both front fenders aren't damaged, engine started first time, chassis ok.
Front Bar Grill only   - Part Number 6231027U06
REINFORCE-FRONT BUMPER BAR  Part Number  6203026U30 - Build Date 02/1997 - 12/1997 on wards suits
Auto Transmission Cooler - Part Number 2162121U61 - see Photos  - Build Date 01/1996 on wards suits
FAN & MOTOR ASSY-CONDENSER  - Part Number 9212015U01   Build Date 01/1996 on wards suits
SHROUD ASSY-RADIATOR  - Part Number 2147581T00  Build Date 01/1996 on wards suits
AC CONDENSER UNIT  Part Number 9211098U00  Build Date 05/1997 - 12/1997
LH + RH Headlights - see photo of my car - special 40th Anniversary S2 with black internals
HEADLIGHTS MUST BE OF A COUPE ONLY - NOT OFF A SEDAN
RH Headlight - Part Number 2601027U25 - Build Date 01/1996 on wards suits
LH Headlight - Part Number 2606027U25 - Build Date 01/1996 on wards suits
I am investigating the below parts also but may have these almost sorted out:
**These are a little harder to source, and preferably want all off one car with a build date 05/1997 on wards**
Also searching for Series 2 Dash, Driver's, Passenger Airbags with ECU and Clock Spring.
Passenger Airbag Part Number K851598U00Build Date 02/1997 on wards suits
Driver Airbag Part Number K851026U20  Build Date 05/1997 on wards suits
ECU  Part Number 2371013U10 - Build Date 01/1996 on wards suits
Clock Spring Part Number 255670M006
I've sourced most of the parts now.
Only need Series II headlights OR passenger side headlight.
I've got RH side but it's not up to scratch as i'd like it to be, prefer a pair in similar condition.
lm also after a power steering motor as seen in the photo the pully has been bent from impact so I'm assuming the motor is possibly damged
PUMP ASSY-POWER STEERING 4911021U00 -01/1996 on wards will fit
And front bar Grill  10/1997 on wards suits apparently
Edited by mercyseat
Thanks everyone for the replies but I ended up finding another 40th Anniversary  R33 entire donor car that's got a suspected blown head gasket  which I bought two day's ago. But it's got heaps of goodies i can convert over to my car.
Build date on mine is 11/1997, Donor car build date 12/1997.=perfect, couldn't have been so lucky. So atm I own 2 x 40th Anniversary R33's.
I'll be pillaging airbags,  front end parts, stainless exhaust to fix my R33 then I will be selling the leftover wreck including the engine that needs repair.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
