On 9/5/2016 at 7:40 AM, Anfanee said:
I just got this (literally 2 weeks ago) and it is fantastic for gaming.
https://www.pccasegear.com/products/31877/acer-xb270h-g-27in-g-sync-144hz-gaming-monitor
Acer XB280HK 28in 4K G-Sync
I recon its worth the extra $85, 1 extra inch but it takes it to 4k.
as i can only run 1 screen  ( i will run a secondary screen to watch movies on while playing stuff) but i dont have room for the 3 screen i wanted for gaming. im looking into the possibility of running 1 very large screen. like a 32-34inch, more money yes, but might be worth it for a single monitor setup.
Edited by GH05T
28" is 60hz @ 4k
27" is 144hz @ 1080
Personally i would go the 27" 144hz @ 1080. 144hz feels A LOT nicer to use even in windows. There is also less strain on the gaming system having to put out 1080 over 4k. That 1070 will struggle a bit on top end games at 4k....
I won't go back to sub 144hz again.
It'll do 4K gaming for sure.
But if you want a solid 60fps at all times, you won't be able to run them on Ultra detail.
A good middle ground may be a 1440p monitor at 125hz+ which your 1070 should be able to do.
Otherwise, Anfanee's suggestion is best bang for buck IMO.
Can't wait to see pics of this rig when it's built.
Its not a flashy rig, its got hidden led ring fans which you can just see through the case mesh and glowing ram and a few logos. Thats about it. Thats how i like it, im not a kid anymore :P i almost wanted a solid cube for a case.
Its so quiet though! The thermal take fans with the stepdown cables are so silent. But they work very well. The watercooler again is silent, i keep checking the temps to make sure their doing their job properly.
the corsair link is a good program too, very good to keep an eye on the temps and all the stats, i like stats :)
Was playing a bit of doom last night on ultra everything and it loved it. Much more enjoyable with good smoooooooth gameplay.
Played some no mans sky. That seems to need some optimizing. Unsure if its the game design being procedural generated or if it just needs tweaking but the terrain building ahead when flying in atmosphere is glitchy as f**k.
keen to fire up project cars tonight but even more keen to get my hands on an oculus and play Project C in VR.....
Love the keyboard. i have spent some time setting up the colourscheme for different games (and here me saying im not a kid haha)
my fav colour shceme out of game is white/ pale blue keys which hit red and fade back out, tracing your type.
but games are surprisingly better when your keys are marked for you and the rest blacked out. especially when playing games like Mechwarrior online where you have a decent amount of shit active on the keyboard.
Edited by GH05T
No mans sky is poorly coded. Your PC should feel lovely man, and with a good 144hz G sync monitor for gaming it will be so smooth.
Realistically you should get 4-5 years out of the processor and stuff. GPU maybe 2 years, it depends on what the gaming industry does. I'm expecting to upgrade my GPU around late next year.
By then a 12xx series will be out. 1180ti or 1260/70/80 will be out. Just replace the card. SLI still isn't worth the dosh for the upgrade. Though G-Sync does fix a lot of the issues SLI had it still is far from perfect.
  • Like 1
My latest purchase:
https://www.pccasegear.com/products/34610/corsair-h5-sf-low-profile-liquid-cpu-cooler
Building a miniITX gaming rig has it's limitations. One of those is cooling/space, apparently this thing hauls ass so hopefully i can push my PC even more.
  • Like 1
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
