R33 wheel fitment
Hey guys been doing some reading and cant get a definite answer, wanted to know if
17x9.5 with -20 offset
Will fit inside standard gaurds if they get pumped/rolled, was trying to figure if they wuld or not before i order them
Thanks in advance
Edited by Beauc32
https://www.sau.com.au/forums/topic/466479-r33-gtst-wheel-fitment/
no way they'll fit
-20 is way off
+30 is the best offset
they'll be 20mm outside the guards and that's rolled and flared
I have 18 x 9.5 + 30 all round
Dead flush with rolled and flared guards
Front rims hit the control arms a bit, I took out some with an angle grinder.
There's a sticky wheel offset thread..
Edited by conan7772
  • Like 1
On Thursday, August 25, 2016 at 9:21 PM, conan7772 said:
no way they'll fit
-20 is way off
f**k that sucks guess i better look for different wheels aha
Cheers for the help ??
  • 3 weeks later...
My old 1994 R33 GTST Coupe  I got 18 x 8.5 on the front and 18 x 9.5 on the back with zero rolling or offset.
The front rims though were that close to the brake caliper , no more room left...
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
