Hi guys,
I Have for sale a set of Garrett 2860-5 turbo's.They have traveled approx 10,000 kms. These WERE in working condition when I originally sold them in March. The buyer sent these back to me a couple months ago after what I believe his mechanic stripped an oil feed thread and making one of the cores unusable. Due the the sale being done via PayPal, the buyer has up to 180 days to come back and demand a refund. I had to refund the money and received back a set of damaged snails in the process!
I have had GCG inspect the thread and they have said that you could try and use a screw in fitting which would require the installation of braided lines. Personally, I wouldn't go down that path. However, if you wish to try and they do leak oil that is all on you! What these turbo's could be used for is to put GTX wheels into the housings as many guys use -5 housings for this reason. Another option is to re-core the turbo that has been damaged and you will have a cheap pair of -5's, one core brand new, one core doing approx 10,000 kms.
- Very little shaft play.
- The turbine housing's has been ported to match the manifold to turbine housing gasket.
- The turbine housing's has been cermaic coated.
- The actuator arm has been modified to increase leverage against the wastegate flap. The actuators are currently set at 19-20 psi from memory. I have had the actuataors set upto 24 psi. This work was carried out by RacePace Motorsport in Melbourne.
- There are two missing studs on one turbine housings..
- Turbo's are Located in Georges Hall, NSW.
- Buyer will pay for postage if required.
- NO PAYPAL!!!
- Turbo's have been priced in accordance to their condition and the extra bits mentioned above which are worth a small fortune in themselves. Unfortunately this is not my fault but I have been left holding the baby.
- I take no responsibility for a faulty installation.
- Please understand that one of the oil feed threads is stripped. I cannot stress this enough!
- When received, can you please confirm that these are the items listed within 7 days. This is a condition of sale! I am not interested in hearing back from you in 6 months time with a Walt Disney fairy tale!
Price is $600 ONO.
Contact me through PM.
TURBO 1
09476DD0-6FC6-4A7A-B265-FFB539A8905E_zps
Thread 1
0945BF67-43DB-4A14-AB7C-440087D6E4A8_zps
Thread 2
7B80CF8E-E5E3-48A0-8951-7C7F412BB9AD_zps
Thread 3
17FBE292-67BC-45B1-8361-28A3F6FD975B_zps
Turbo ID tag
B51109E6-6F6D-4D6D-995A-B728D8C5BDAB_zps
Ported turbine housing.
47B7AB87-D94B-42B8-A593-E9AEEAFFE0B0_zps
Modified actuator
19203A38-CB6C-49E2-90D2-EAE1BA509735_zps
TURBO 2. This is the damaged turbo.
EB8070F2-0AA3-4404-B067-CC932029A5C5_zps
Thread 1
ABB40676-8793-40FD-8569-20AFD233C174_zps
Thread 2.
FCCFF3B5-C47F-480E-B712-2EBFE27BFC1E_zps
Thread 3. This is the damaged thead.
481D4DF8-8051-4EEC-859C-7997ADE37924_zps
5B379359-519B-4C34-B9A0-F4C26344F72B_zps
Modified actuator arm
9F14E2F9-350C-48DB-B9CB-653550B4AE2F_zps
Turbo ID tag
8DE0D455-E4D4-4B4A-85C6-6B683A8E9C02_zps
Cheers,
Paul.
https://www.sau.com.au/forums/topic/466496-garrett-2860-5/
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
