Hi everyone!
I'm new to this forum, i am finding these forums to be very educational and time consuming during work hours :jump:
Just wonder if someone can list what needs to done on a regular say 10,000km service on a R33 Gts-t?
And also can someone recommend somewhere to get my car serviced in Canberra?
Thanks,
https://www.sau.com.au/forums/topic/46650-servicing-your-r33/
Hi Trader33, welcome.
To service your car, you'll want to:
- Change the motor oil and oil filter... every 5,000kms.
- Change your spark plugs... coppers, every 10k kms, iridiums, much longer. :)
- Change your coolant fluid... erm... umm... I've changed mine twice for the 30k kms I've had my 33, so... every 10k kms? :D
- Change your fuel filter. I get the mechanic to do this whenever I'm getting something else done... or you could do it yourself if you want, @ $15 for the filter... I'd do it at 10k km mark.
Anyone want to add anything on? There's guides here: http://www.skylinesaustralia.com/forums/sh...ead.php?t=35442
- Change your coolant fluid... erm... umm... I've changed mine twice for the 30k kms I've had my 33, so... every 10k kms? :rofl:
isnt the fuel filter every 100,000km? i changed mine, but that was related to a stalling issue.
trader33 - if you live in Canberra then go to All Make Automotive in Garran, beside the Mobil servo or TEZ automotive in Mawson.  Highly recommend them.
I'd also recommend the Mobil servo at Garran - see the thread in the ACT section about servicing :)
No, you're thinking of the timing belt. :)
I honestly don't know what the 'correct' period for the fuel filter is, but considering I put (on average) 300-400 liters of fuel (that came from dirty underground tanks) per month into the engine (via a dirty fuel tank from the car), and they're so dirt cheap (pun intended) to buy, it doesn't hurt to change them regularly. Besides, a new filter will eliminate another suspect in tracking down problems.
  • 1 month later...
What Fanny said. :mad:
I've never actually changed a fuel filter myself (don't like getting fuel on me hands)... but you should be able to get a code off the old filter. You don't *really* need 'CODE XYZ' filter, since it's not actually fitting onto anything mechanical like an oil filter fitting onto the side of a block. You just need one that will fit in the hoses snuggly.
I get mine changed by the mechanic and it costs like $12 in 'parts'.
its easy to get one hose off but a pain in the ass to get the other one off.  after hlf an hr of blisters and cursing i just cut the damn thing!!  quite an easy job to do though and i did notice the car to be alot smoother after it.
:werd:
both hoses were a little stubborn on the weekend, patience.....lots of patience (not a stanley knife) got mine off.
placebo or not?!?! seems to be running better.
Shouldn't be too placebic... you're replacing something that was restricting the fuel flow (when it's very dirty)... it should start easier, be smoother, blah blah blah.
Did you have to seal off the hose from the tank, or did you just let it drain out?
i doubt it's placebic (is that a new word??!! nice!) too, genuinely feels better but i am a sceptic at heart.
i didn't seal off the hose, there was a small amount of return from downstream, upstream was no problem. if it wasn't for the goddam @#>*#@ difficult hose removal it would have been reasonably neat. i contemplated plugging the lines after i pulled the filter off but any spillage was well and truly done by then.
best thing to do when changin the fule filter is to remove the fuse for the fuel pumo....then crank the car. IT'll stall once it's used all the fuel in the lines...then put the fuse back in and away u go...no fuel in the lines :D
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
