Hi everyone!
I'm new to this forum, i am finding these forums to be very educational and time consuming during work hours :jump:
Just wonder if someone can list what needs to done on a regular say 10,000km service on a R33 Gts-t?
And also can someone recommend somewhere to get my car serviced in Canberra?
Thanks,
https://www.sau.com.au/forums/topic/46650-servicing-your-r33/
Hi Trader33, welcome.
To service your car, you'll want to:
- Change the motor oil and oil filter... every 5,000kms.
- Change your spark plugs... coppers, every 10k kms, iridiums, much longer. :)
- Change your coolant fluid... erm... umm... I've changed mine twice for the 30k kms I've had my 33, so... every 10k kms? :D
- Change your fuel filter. I get the mechanic to do this whenever I'm getting something else done... or you could do it yourself if you want, @ $15 for the filter... I'd do it at 10k km mark.
Anyone want to add anything on? There's guides here: http://www.skylinesaustralia.com/forums/sh...ead.php?t=35442
- Change your coolant fluid... erm... umm... I've changed mine twice for the 30k kms I've had my 33, so... every 10k kms? :rofl:
isnt the fuel filter every 100,000km? i changed mine, but that was related to a stalling issue.
trader33 - if you live in Canberra then go to All Make Automotive in Garran, beside the Mobil servo or TEZ automotive in Mawson.  Highly recommend them.
I'd also recommend the Mobil servo at Garran - see the thread in the ACT section about servicing :)
No, you're thinking of the timing belt. :)
I honestly don't know what the 'correct' period for the fuel filter is, but considering I put (on average) 300-400 liters of fuel (that came from dirty underground tanks) per month into the engine (via a dirty fuel tank from the car), and they're so dirt cheap (pun intended) to buy, it doesn't hurt to change them regularly. Besides, a new filter will eliminate another suspect in tracking down problems.
  • 1 month later...
What Fanny said. :mad:
I've never actually changed a fuel filter myself (don't like getting fuel on me hands)... but you should be able to get a code off the old filter. You don't *really* need 'CODE XYZ' filter, since it's not actually fitting onto anything mechanical like an oil filter fitting onto the side of a block. You just need one that will fit in the hoses snuggly.
I get mine changed by the mechanic and it costs like $12 in 'parts'.
its easy to get one hose off but a pain in the ass to get the other one off.  after hlf an hr of blisters and cursing i just cut the damn thing!!  quite an easy job to do though and i did notice the car to be alot smoother after it.
:werd:
both hoses were a little stubborn on the weekend, patience.....lots of patience (not a stanley knife) got mine off.
placebo or not?!?! seems to be running better.
Shouldn't be too placebic... you're replacing something that was restricting the fuel flow (when it's very dirty)... it should start easier, be smoother, blah blah blah.
Did you have to seal off the hose from the tank, or did you just let it drain out?
i doubt it's placebic (is that a new word??!! nice!) too, genuinely feels better but i am a sceptic at heart.
i didn't seal off the hose, there was a small amount of return from downstream, upstream was no problem. if it wasn't for the goddam @#>*#@ difficult hose removal it would have been reasonably neat. i contemplated plugging the lines after i pulled the filter off but any spillage was well and truly done by then.
best thing to do when changin the fule filter is to remove the fuse for the fuel pumo....then crank the car. IT'll stall once it's used all the fuel in the lines...then put the fuse back in and away u go...no fuel in the lines :D
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
