R32 GTR - Aftermarket Radiators and Factory Shorud
WantGTR
 Share
Hi All,
Have been looking around and it seems some of those with aftermarket radiators have hacked up/no shrouds and others have them intact. Who here has a aftermarket rad with a factory shroud that fits?
Koyo radiator, factory fan and shroud. No touch. I also installed new radiator bushings and pulled them all the way forward on install. Worn bushings could have caused mine to hit. Another option would be to machine some offest bushings pulling the radiator further forward
14 minutes ago, bcozican said:
sometimes that chopping etc of the shroud/ rad from the fan comes from worn / broken engine mounts when the car brakes etc the engine can move forward hence closing the gap / changing the alignment of everything... been there !
Engine mounts maybe.  In my case and at least a couple of others I've seen it's simply the radiator getting sucked back towards the engine by the engine fan.  It doesn't seem to happen with stock radiators, so maybe they are just too thin (to take up the room) and too thin (to put up enough resistance to airflow) to move far enough against the rad mounts.
I just jammed some more rubber into my upper mounts (on the back side) to pre-load them and prevent it moving back.....well, after it has already sliced a line through my shroud!
I've got a cefiro, so not a gtr. But,
I run a 52mm rad with the stock shroud and fan. Had a few drama's with the fan hitting the shroud.
I machined some new lower bushes out of nylon, and made new brackets for the top with no bush.
Haven't had a issue since. Car is used for drifting so gets a bit of a thrashing. Tried twin thermo's early on, and they were shit.
Granted, they weren't expensive ones, but stock fan and shroud is simple, and it works.
Oh and don't underestimate how much the stock fans flex, I had a Z32 fan (greater offset, but had one lying around) on after the thermo's shat themselves , had a decent 15mm gap fan to rad and it still grabbed the radiator at high rpm.
What is the thickness of factory radiator?  Mishimoto is only 32mm so it should have fewer clearance issues, and 10% cheaper than Koyo here.  They also have great lifetime warranty that even covers collision.
1 hour ago, Dan_J said:
well i personally dont, but hey each to there own....
only if done right.. and 9/10 times it is done wrong...
Most owners just hard wire their fans OR use shitty fan controllers that turn off and on constantly like a strobe light.. followed by those who just hook it up to their OEM overheat fan relay/thermoswitch.
You need a proper fan controller either a standalone unit OR through your car's aftermarket ECU to set OFF and ON points followed by some form of hysteresis - only then would that be consider an appropriate installation.
 Share
    • I'll snap up some photos when I'm back home, in the office today meeting my "in the office" quota. Have 2x Teams calls scheduled in, office culture they reckon.   I've never owned a proper off the shelf sub, I've always made or modified broken ones with Jaycar plate amps and/or car subwoofer drivers. The current (and broken) subwoofer has a proper home driver in it, Dayton driver, thos one https://www.daytonaudio.com/product/118/rss265hf-4-10-reference-hf-subwoofer-4-ohm FS of 25Hz, which is low but not low enough. Yeah, I think they were brought out to the market to compete with SVS. I would love a SVS PB-3000 but they're not cheap, especially after their price hike. From reviews online, it does look like the Tonewinner D6000 would destroy and with good amount of money saved too.
    • yeah, that happens too.  I'm really enjoying 4WDing at the moment, seen a few beautiful spots and want to go explore more of this enormous country.  The 370Z got a clutch LSD in it and a track day, great fun.  Getting the back end sorted out really rejuvenated my enthusiasm for driving it hard, the viscous one is poo especially in such a short and wide chassis.  The VLSD unpredictability was more benign in a long and skinny Skyline.
    • With my pre/power I use a remote trigger cable(3.5mm jack each end). I turn tv on, it turns both on via ARC. Or, just the pre with the remote or its streaming software, turns on both. Not that difficult at all. Obviously,  you would also want to actually update/upgrade over other factors in your life(bills, family, other hobbies, etc)
    • Yeah, nightfall was very "meh". And I'm crap at pvp, so feels like everyone has cheats(it's just my lack of skill). Final shape has been pretty good. New raid and dungeon are pretty good. If you want to give it a go, probably wait until it's on sale. But, as usual, most of it feels very familiar.
    • This morning was Kingswood's Microscopic Wars. It is the album's 10 year anniversary this year and we went to see them play the whole album as a special show a couple of months back. Was pretty spectacular.
