r33420 Posted August 28, 2016 Share Posted August 28, 2016 (edited) Hey guys I need some help identifying this diff I pulled out of my r33. I bought a stock r33 diff and got them swapped because this one was a nuisance to daily drive. Every time I turned at low speed the car would bounce/shudder. When I bought the car the guy said it had a Nismo 1.5 Way Diff. I thought something was wrong with my car then after googling the symptoms I found that those diffs are supposed to make heaps of noise at low speed turns so I bought a stock r33 diff and got that put in. So now I want to sell the "Nismo 1.5 Way" but I want to make sure it is one so I don't rip anyone off. What do you guys think? I can take more photos if you can't tell from these. Cheers. Edited August 28, 2016 by r33420 Link to comment https://www.sau.com.au/forums/topic/466523-need-help-to-identify-this-diff/ Share on other sites More sharing options...
Duncan Posted August 29, 2016 Share Posted August 29, 2016 The key pic internally is to take the inside of the hole you can just see in the first pic. Assuming its a mechanical centre there are ramps inside that determine if it's 1, 2 or 1.5 way, they look like |/, \/, or a halfway between those 2 respectively. Also there will be a ratio stamped on the main gear as well, something like 37:9 which is the 4.11 diff. edit, cancel that, I can see you have that in the 3rd pic I don't know how to tell the brand of the centre, others might, but personally I don't think it matters too much Link to comment https://www.sau.com.au/forums/topic/466523-need-help-to-identify-this-diff/#findComment-7770680 Share on other sites More sharing options...
r33420 Posted August 29, 2016 Author Share Posted August 29, 2016 Alright sweet thanks man I'll have a look when I get home Link to comment https://www.sau.com.au/forums/topic/466523-need-help-to-identify-this-diff/#findComment-7770701 Share on other sites More sharing options...
