Hey guys,
Was out for a cruise today with a mate. Giving the car a hard flog. All of a sudden I heard this loud whistling. Sounded like a typical boost leak. Checked clamps hoses and all looked good.
Noticed this when I pulled everything apart. The intake pipe was made by nm Scotty and it's actually pretty solid.
Has anyone seen this before?
Cheers,
Chris
If I were to hazzard a guess.
I would say that your intake pipe and filter are solidly attached to the body.
I think the engine has rocked over and mashed the intake pipe and turbo snout together.
Hot aluminum bends pretty easily
  • Like 2
you sure it didn't get bent during install and you've jut noticed now you're looking for issues? just a thought.
Yeah I only put the car back together two weeks ago. Definitely would have noticed if it was like this before
Hard to say, if I had just seen the charge piping only I would have said the clamp was over tightened. However like others taid the clamps where too tight, it got hot and some engine movement occurred pushing the charge piping up against the compressor housing. I would leave a 3/4" gap between the piping and housing next time. Also check your motor and transmission mounts.
  • 3 weeks later...
Looks like the clamps were over tightened to me, were you using those shitty Tbolt ones, or Norma style worm drive?
You should be able to straighten it out with a ball head hammer and gently tap it back into round.
How tight do you typically do up your hose clamps?
I tighten all intake plumbing using a socket driver rather than a ratchet, this gives more feel and less chance of over-tightening. Comparing your 1st and 2nd photos, the worm drive of the hose clamp is in roughly the same spot as the bend in the intake pipe. That is usually where the most pressure is too. It's possible it sealed until a few heat cycles and then let go, leading to an air leak.
Edited by colourclassic
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
