Hi guys, decided to start a build thread on the forum as I've been asking some advice on this forum and probably will be asking more in the future.
Since I have my car for a while already the first post will be somewhat of a summary of what has been done to my car up to now.
So, my car is a 1997 R33 GTST which has the URAS R334 conversion kit, not something you see that often( and not to everyone's liking).
10377535_1493028874317922_73075963091136
When I bought the car the engine was basically stock except for: FMIC, HKS air filter and an Apexi catback system.
As with most Skyline's it didn't take very long before the first upgrades were ordered, so in came the: Tomei Poncams, new FMIC and piping as the old piping had too many couplers to my liking, Nismo Super Coppermix clutch + lightweight flywheel, Splitfire coilpacks, Apexi 3 inch front pipe, Tomei Expreme turbo elbow, decat, Apexi boostcontroller set to 11 psi, chipped ecu by RSP/Dynotuner in the UK.
After a while the car developed a misfire on one of the cylinders which could be fixed(temporarily) by revving the engine hard, this misfire started to get worse and worse after a couple of weeks until the car got hard to start.
At that point I decided to do a comp test and.... yupp 0 compression on cyl 6, so off with the head and then the problem became evident. 2 valve guides had cracked and were missing pieces.
2 of the valves were bent probably because i was driving the car with the broken valve guides for a while(even raced it like that lol).
So 2 new valves and some maintenance parts later the head was back on and it was happy again.
IMG_20150612_195243_edit1_zpslksegcpb.jp
Edited by iTzTMG
  • Like 2
https://www.sau.com.au/forums/topic/466594-project-r334-from-the-netherlands/
Like a lot of Skyline owners I like motorsports and my choice of motorsport is dragracing, as I grew up in Curacao(island in the Caribean) before moving to the Netherlands, I was raised in the dragracing scene as it is the most popular motorsport on the island.
So that is also the type of racing that I now use my Skyline for. My goal for this year with the current setup was to try and get the car in the 13's, unfortunately I haven't been able to do so and I end this season with a best of 14.2 on the 1/4 mile.
 11081196_868675073171332_461717909259034
11410647_1775514652675011_2009871837_n_z
I've been struggling with traction a lot and decided to get a set of Mickey Thompson ET streets on 16" R32 GTR wheels which I tested last weekend but this also did not help, only managed a 14.4 with a 2.260 60ft at the last event. It seems that the car is just not making the power it should(currently on stock ecu).
My original plans were to get a hybrid turbo, Haltech, some injectors and run that for a year and slowly upgrade the car but then I thought I should just spend the money once and go all the way.
Edited by iTzTMG
  • Like 2
And that's where I am at now, the start of Project R334....
Instead of going the hybrid turbo way I've decided to set my goal for next year at running 11's on the 1/4 mile, to reach that goal I've decided on the following setup:
- CP pistons 87mm with upgraded piston pins
- Spool H beam rods with ARP bolts
- ACL race bearings
- ARP head studs
- Supertech +1mm valves(inconel ex, stainless in)
- Supertech valve springs + titanium retainers
- Supertech valve seals
- Bronze valve guides
- Spool head drain kit
- Tomei poncams
- NX nitrous system (wet)
- AEM water methanol injection
- Precision Gen 2 6466 turbo (T4, .84 AR, split pulse)
- Tial MVR 44 mm wastegates
- Haltech Platinum Pro ecu
- ID1000 injectors
- Deatschwerks 340 lph fuel pump
- Topmount manifold by CRG (T4, split pulse, dual wastegate)
- Front entry intake manifold
Manifold by CRG in progress
14017644_1290588494298745_1769772863_n_z
For now it's just a collection of parts laying around at home and a lot more parts are needed but the plan is to hopefully start putting it together soon. It would be nice to have it all finished up by the start of the next dragracing season(June next year) but we'll see.
We all know deadlines for these kind of projects are rarely met and I rather have if built right instead of finished fast.
For those on Facebook, I have a page where I'll be posting photos/videos of the project and events that I visit here in the Netherlands so if you're interested please like my page https://www.facebook.com/projectr334/ it'll be very much appreciated.
Of course progress will also be posted in this topic.
Edited by iTzTMG
  • Like 3
13 hours ago, admS15 said:
Welcome. Looks like it's turned into a serious build. Nice collection of parts there. Should get you into the 11's easilyemoji106.png
Thanks!! I sure hope so :)
11 hours ago, PranK said:
This looks fantastic! Great build! I think it needs a build thread!
:welcome:
Thanks! I'll keep you guys updated on the progress of this.
2 hours ago, V28VX37 said:
Great stuff, thanks for sharing!
Is there like a European Recruitment Drive for SAU on or something, lots of awesome overseas builds being posted at the moment?!
Thanks!
The Dutch and UK forums aren't as big and active as SAU, I've been reading on this forum for a couple of years now, so it was about time to share my project since I'm sure I'll be asking questions now and then.
  • Like 1
  • 1 month later...
So just a small update on the progress of my build:
Ordered a lot of small stuff like seals,gaskets, bolts, standard water pump, crank collar( thanks to KiwiRS4T) and N1 oil pump.
Decided to go with the N1 oil pump and will be getting billet gears for it, as I'm not planning to raise the rev limit too much I think it should be ok.
Also picked up a bare block and a head 2 weeks ago, these will be used to build the new engine so I don't have to start taking my car apart just yet.
I am picking up another head this weekend tho, as the previous one has some damage to the squish pads of cyl 5.
First I was thinking to have the squish pads removed but as I already have pistons which are the OEM style it might be better to go with another head so it won't affect the compression etc.
I did start on removing the bump in the exhaust ports of the damaged head, so I'll continue with that and might keep it as spare and do the same to the other head.
Also got the manifolds from CRG and Otaku Garage so I had to test fit them and take a few photos(not the best quality photos):
The block and head will be off to the machine shop soon so hopefully some more updates soon.
  • Like 1
  • 7 months later...
As I was afraid of, not much progress has been made on the build unfortunately.
I had to move out of the garage I was renting, travelling for work, girlfriend that wants to go on holidays so basically the build moves at a much slower pace for now.
The car however does drive and a few little things have been done to, like the NX Nitrous system is now fully setup and consists of the following:
  • NX proton plus wet kit(running 35-50 shot).
  • NX 10lb bottle with lightning valve
  • NX bottle heater kit
  • NX purge kit
I am still on the stock ECU and that seems to hold the car back quite a bit but I am going to hook up the Haltech and bring it in for a tune on the current setup before the end of July, so hopefully that will bring some improvement.
Edited by iTzTMG
A short video edit I made
Looking to do more of these in the future, also with more racing footage.
For those interested, I really appreciate it if you like/follow/subscribe to my social media channels:
  • Like 1
  • 2 months later...
Last weekend we had another dragrace event here in the Netherlands and I had another go at it.
The weekend started off quite badly with some ones party tent landing on a few cars, one of which was mine.
So I have some paint missing and a scratch from left to right on the windshield, besides that our own tent couldn’t handle the strong wind and collapsed after a few hours.
Managed to get two runs in on Friday and the first run was a new PB for me, ran a 14.0 with a 2.1 60 ft.
Second run I managed to do a 13.5 with a 2.0 60ft and I was very happy with that as it is the first time I managed to get the car in the 13’s.
Saturday started off with a lot of waiting for the track to be ready for qualifyingand when I finally got to run again I managed to run 2 more 13.5’s and a 13.199 @ 163 km/h with a 2.0 60 foot.
I was very happy with that as it was a whole second off from the times I was running at the event in May.
I qualified 3th in my class and on Sunday we were supposed to run the finals but due to bad weather I only ran one race after which the event was stopped, as I won that race and qualified as number 3 I took home 3th place this time.
So overall it was a decent weekend, with me finally running in the 13’s.
This is on the stock engine, stock turbo, stock ecu and a 35 shot of nitrous from the Nitrous Express Proton kit.
Some pictures taken at the event
Now let’s see if I can get it in the 12’s next time xD
  • Like 2
  • 2 months later...
Last weekend was the last race weekend of our drag race season and as usual I participated.
The first day I managed to do 4 runs which were all in the 13.2 - 13.5 region, on the second day I only managed to do 1 run as the track was closed due to the bad weather.
The last day I ran 5 times of which the first run was quite bad as the track did not have any grip at all, it resulted in a lot of wheel spin and me failing to get it in second gear which resulted in a 14.5
The remaining runs all came as a surprise to me as I first ran a 12.97 then a 12.83 , 12.71 and finally ended with a best of 12.667 @ 173.8 km/h with a 1.956 60 foot
The best 60 foot I managed to get that weekend was a 1.842
I’m quite happy that I managed to get my car into the 12’s on the stock turbo/ecu setup with a little help of a 40hp shot of nitrous.
Now to see what I can change for next year and in the meanwhile I will be slowly building the new engine.
  • Like 3
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
