Hola
Hello everyone,
I've been around R31s for quite a few years, purchased my first R33 a couple of months back and love it. Already spent some coin on it, with much much more to come. Looking at making it a reliable 300kw street/track car.
https://www.sau.com.au/forums/topic/466595-hola/
It is a S2.
Currently has: GFB elec boost controller, GFB elec blow off valve, FMIC, 3" magnaflow exhaust, Extreme twin plate race series clutch, Tein coil overs, break upgrade
Planned: Larger turbo, plazmaman intake, upgrade ignition system, upgrade fuel system, aftermarket computer, E85, tune, upgrade suspension, eventually forged internals.
4th gear syncro is on its way out so ill throw a new gearbox in it next and then swap out the diff to a stronger LSD. should make for a reliable fun car. My target is 300rwkw.
https://www.sau.com.au/forums/topic/466595-hola/#findComment-7771865
Hey mate, welcome. Before you go changing gearbox, you may want to check how much oil is in there. Mine used to crunch into fourth at high revs and it turned out there was only 2.5 litres of oil in it when there should be 3.6 - 3.8 litres. I changed the oil and refilled with the right amount and the box has been beautiful since.  Worth a try before you go to the effort of changing boxes and obviously the cost of it too.
https://www.sau.com.au/forums/topic/466595-hola/#findComment-7771866
The mechanic that put the clutch in couldn't get the drain plug out of the box to change the oil, so there is a good chance it may be low, i might find a hoist, have a crack at the plug myself and throw some oil in there.
thanks
https://www.sau.com.au/forums/topic/466595-hola/#findComment-7771943
Got it on the hoist, took about half a litre of oil, took it for a drive and 4th gear is still troublesome, it is only at speed that it has an issue which is a little confusing, I can't engage 5th to 4th, but I can if I go 5th, 3rd, 4th.
https://www.sau.com.au/forums/topic/466595-hola/#findComment-7774501
drop in Nulon Smooth shift addictive, usually helps with these shit boxes (literally)..
Mine grinds in 2nd at 7k rpm, but a workaround is to bash the limiter and slip it into gear... 3rd and 4th grinds too, work around just shift as hard as you can "reef" it into gear LOL... #traklife
Yours looks so much cleaner than my shit box :)
Does it dose good?
https://www.sau.com.au/forums/topic/466595-hola/#findComment-7774678
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
    • Welcome (back) Gaston! Keep us up to date with the hunt!
