Clints 32 GTR
Hey guys, I got this GTR November 2015. Bought it unlicensed and with a blown turbo. Here's a few pics from just after I got it.
Was pretty much stock, I picked up another pair of stock turbo's, Replaced a few bushes/balljoints, fixed a small rust hole in the passenger foot well and went over the pits and got my plates :D
One of the first things was a new set of wheels (the silver 17's were ok but not my cup of tea) so picked up a set of 18x10 Grids which I shortly after wrapped with Nexen SU1 275/35-18's all round. (Great all round tyre btw)
Sold the set of Kei Office coil overs as the springs and dampeners were super stiff and Replaced them with a Set of Tein's
Focusing on getting the suspension and driveline at first I soon fitted the following:
-URAS adjustable front upper control arms
-ZSS adjustable front castor arms
-Hicas Eliminator kit
-Rear subframe pineapples
-Diff Pinion bushes
-New tailshaft center bearing
-Torque Split Controller
Since the diff was clunking abit I decided to do a rebuild. I had to pull the diff and take some measurements before I knew exactly what parts I needed to order. I pulled it apart and ordered new bearings, Nismo clutch kit, seals, shims etc Unfortunately there was going to be a 2 week wait for some of the parts.
  • Like 1
https://www.sau.com.au/forums/topic/466611-clints-32-gtr/
Sooo since the car was going to be off the road for two weeks I suckered my gf into helping me paint the car :) I did 90% of the prep at home but it helped that I was running a Custom car workshop at the time so took it to work to finish the final prep and lay down the color in the booth. Unfortunately my phone went through the wash a couple months ago and I lost heaps of pics relating to the car... But I did post a few to Facebook so here are those.
Was just a closed door job in the Original Red Pearl Metallic, Had a couple issues but overall very happy with how it turned out and will serve me well until I decide to do a full on respray.
Got the diff back together shortly after but lost all the relatic pics :( Then after abit of driving noticed a relay clicking on and off all the time... Abit of research I discovered it was likely my Hydrogen resi which is part of the AWD system. So grabbed a new item from Kudos motorsport and that sorted that.
Continued buying and fitting various bits and pieces (was sorta addicted to online shopping) ill run through a quick list.
-GTR Tyre valve caps (Ebay)
-Full set of Interior LED globes (Ebay)
-Suede Steering wheel (Ebay)
-New handbrake / shifter boot (Ebay)
-New Interior door handles, Dash Vents, center console surround (Kudos Motorsport)
-Various rubbers & clips (RHD Japan)
-Silk Road front undertray (2nd hand Facebook)
-Nismo Oil cap (Ebay)
-Nismo Center caps (Ebay)
-Fuel tank seal, Brake shim kit, Radiator bushes,  (Kudos Motorsport)
My missus was nice enough to buy me a set of GTR floor mats,dash mat and matching GTR Jumper :D
Next I was after abit more power as to be frank I was quite disappointed in the stock GTR power. Picked up a Nistune, fitted a HKS boost controller and strapped er down on the Dyno... Abit of tinkering saw power climb to just shy of 300rwhp. (lost the pics of most of the dyno sheets on my old phone but I do have this one which was a comparison of my stock turbo 33 to the stock turbo 32r.... Can see how much more responsive the 33 is altho peak power is not as high)
Edited by PranK
Fixing pics.
  • Like 4
https://www.sau.com.au/forums/topic/466611-clints-32-gtr/#findComment-7772105
Anyway since I am planning to move to Tasmania in the very near future I didnt want to go too far from stock as I will need to pass pits again once I move there. So I kept work mainly restricted to replacing anything that needed it... which after noticing a leak from the body of the stock injectors which I soon found out was a common issue I fitted a Turbosmart FPR800 fuel pressure reg, set of 850cc Siemens Deka Injectors, Fuel rail and Walbro 255 fuel pump.
Next one of the front CV boots split, so front Axle rebuild was on the cards. While I was at it I replaced the outer CV joints as well as the boots. Could not find inner CV's so just inspected, re-greased and new boots on that end as well as new diff side seals, front seal and oil.
Before and after of the drivers side axle:
A pair of Stainless split dump pipes came up for sale on facebook so I grabbed them and ordered a front Y-pipe also. here is a comparison next to the stock Y-pipe
I found the dump pipe hole where the waste-gate pipe enters the main pipe was actually quite alot smaller then the actual pipe so I got the die grinder out and hogged it out to match the pipe size... here is a before and after (highlighted the hole in the before pic as was hard to see so circled it)
Now I was hoping it was going to be quite a easy job to fit the dump pipes and Y-pipe... Turns out I had to remove the Dam turbos again to get both dump pipes off!
I had also noticed the Gearbox mount had sagged abit and the gearbox was occasionally touching the crossmember so grabbed a Nismo strengthened mount and some crossmember bushes... Painted the crossmember while it was off and fitted the new bits.
gearbox crossmember bushes.jpgNismo gearbox mount.jpgpainted gearbox crossmembe.jpg
Edited by PranK
Fixing pics.
  • Like 2
https://www.sau.com.au/forums/topic/466611-clints-32-gtr/#findComment-7772110
Im sure there is stuff ive missed but thats pretty much up to date... A Haltech PNP came up for sale at the right price so I snapped that up and just been road tuning that lately and enjoying the car... We are getting ready for the big road trip from Perth To Tasmania is this so will be a few more interesting items coming soon.... But this is how she lookes atm.
Edited by Clintox
  • Like 4
https://www.sau.com.au/forums/topic/466611-clints-32-gtr/#findComment-7772111
On 9/2/2016 at 11:52 PM, Clintox said:
Sorry guys, Dont know why the pictures keep doubling up... I cant seem to fix it either?
Its a known issue, driving me nuts, working on a fix.
Loving the thread, car looks gorgeous!
https://www.sau.com.au/forums/topic/466611-clints-32-gtr/#findComment-7772474
Well no one wins the prize for guessing what it was, but here it is anyway... Since im moving from Perth To Tasmania I decided to drive the GTR across. I had only just done a closed door respray a few months prior so in the interests of protecting the paint I was deciding between either plastidip or Vinyl wrap... until I saw a pic of the 1991 ATCC Bathurst winning GTR which got me thinking. after a few emails I found a sponsor to supply the individual stickers for me (Cheers to Steve at stickerstudio.com.au) so all I had to do was sort out the basic red, white and blue.
We actually left on the 21st Sep and are currently in Whayalla, not too far from Adelaide
Esperance
Cocklebiddy:
SA - WA Border
Edited by Clintox
  • Like 6
https://www.sau.com.au/forums/topic/466611-clints-32-gtr/#findComment-7778471
What an awesome drive that would be! You'll have driven more in the last week than I have in mine in 5 years!
A lot of Nissan lovers would have got a kick out of seeing that flying through the desert!
Good job.
https://www.sau.com.au/forums/topic/466611-clints-32-gtr/#findComment-7778520
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
