They are a "Thule" brand Rack but could not find anything at all for a 2 Door skyline (which wasn't surprising) So I had to buy a rack for a Toyota Yaris, cut the mounts up and modify them and moulded new feet out of silicon sealant so they matched the roof profile properly :)
  • 3 weeks later...
Yep that was me, Had just left Brisbane and was heading for Sydney :)
Extremely happy with the GTR, Over 8000km across all but one of Australia's Territory's with the only issues we had being:
-Clutch clevis pin popped out, must have been missing the split pin (5 minute fix)
-Horn jammed on when I turned steering full lock, have not investigated why yet, just pulled the relay for now (1 min temp fix)
-One of the adjustable castor suspension arms unwound itself after we went off road for about an hour down one of the tracks SIRI sent us down making the steering wheel 1/4 way off center (15 min fix)
-Close call with a small roo/other car
-Too low for the crazy eastern states driveways that dip 1000meters into the gutter, even tho the car isn't that low! (scratched up the front lip)
Best we got was 11.3L / 100km with the average around 11.7L/100
  • Like 2
  • 3 weeks later...
So had a good look under the car just inspecting for any damage/wear from the trip... Besides being absolutely filthy (dirt/dust) everything seemed pretty good, being aftermarket arms with heim joints I pulled them all apart and gave them a clean out... Found abit of crap got into one of the rear traction arms and noticeable wear on the rod end so will replace that.
Also found the drivers side outer steering tie rod had abit of play... I happened to find these tie rods on UAS which they say help fix some of the bump steer issues when you lower the car.
http://www.uniqueautosports.com.au/Parts-Shop/front-bump-steer-correcting-tie-rod-ends-584.aspx
But then found these from the guys at Shift Performance Parts, Inner and outer rods that look identical.
https://www.shiftperformance.com.au/product/n1-suspension-nissan-skyline-r32-r33-gtr-gts4-14mm-steering-tie-rods-ends-2/
Anyway bolted it all up today no probs, (obviously changed both driver and passenger sides)
Original:
"N1" Parts, The angle that the balljoint is mounted on the end of the tie rod was quite different compared to stock.
Another interesting this was the inner tie rods had "rack spacers" built into them, Unlike the originals which I purchased a pair of "rack spacer washers" from GKtechIMG_1118.JPG
Setup the toe as best I could with a tape measure, will book for an alignment next week
  • Like 1
So my gearbox wasnt doing so well, 1st Gear was terribly hard to engage even at a complete stop and If I tried to shift into 4th or 5th gear at anything other then grandma speeds she would crunch crunch... even worse at higher RPM.
So abit of research many people recommended "Redline Shockproof gear oil" Now I had recently replaced the oil with some Penrite stuff not too long after getting it licensed and even added some additive (cant remember what it was but supposedly gave smoother shifts etc) so I was a little sceptical that the Redline stuff could be that much better.
Oh how wrong I was... Took it for a fang and not even the slightest crunch! 1st gear is even easy to engage! this stuff is truly Magic!
  • Like 1
I hear that!
My gearbox was woeful changing down to 4th but after it was changed to redline it was a different car.
It really only masks the problem and I know that I will be up for a new gearbox but it has lasted a year and hasn't gotten any worse (yet).
  • Like 1
  • 3 weeks later...
Small update, I bought myself a early x-mass present in the form of a Whiteline adjustable front & rear swaybar kit :)
New Vs Old (had already fit the front one before I took a pic)
Rear Fitted:   (underbody still filthy from the road trip)
Front fitted:
Also picked up and fit a set of solid steering rack mounts:
Last not least, the exhaust system had two mufflers... which was great for passing pits and not annoying the gray nomads at the caravan parks while on the road trip but decided to delete the center muffler hoping for abit more of a note.
Section comparison:
Didn't have any bends and since it was only one decided to just lobster it:
Idle was noticeably louder and deeper as expected, Is noticeably louder while driving but surprisingly not all that much. Only been around the block a few times so cant comment on the swaybars/steering rack bushes just yet... Will take it out to some twisties tomorrow :)
  • Like 2
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
