1 hour ago, gzro said:
600atw would be nice and slightly more, activated via scramble boost when required would be great.
Feedback i have gotten so far is the 0.92 housing fits perfectly on a 2.6l but on a 2.8l with vcam, maybe i should be looking at something slightly bigger.  I already have the 8374 with 0.92 and getting the 1.05 housing alone is not worth it.
So the option now is to stick with what i have or sell the 8374 and get the 9180 with 1.05 housing.  Cant remember where I read this but some posted that the response between the 2 are almost the same - maybe 500rpm difference?
I've got 8374 1.06 on a 2.6
For a 2.8L i'd def go 9180 1.05
  • Like 1
3 minutes ago, Nismo 3.2ish said:
should be interesting to see the 8374/1.05  on a 3.2 with Vcam   handles it
Your goals are a little left to the "norm". Just need to keep an eye on speed.
  • Like 1
Already have the limiter at 7800 with the 6266 . I just feel if you are going early, you do not have to bash it past 6500 , horses for courses . I am busting to see just where it does get Asthma . Probably close to where it is now ?
Keep an eye on the road mate, not the speed. But that speed sensor you picked up for me will come in handy and may keep some moving parts out of the donk, lol
I think this will suit me just fine :w00t:
9 hours ago, usmair said:
By the way gents, I'm gonna cram another 3-4 psi into the 8374 towards June/July when the weather cools down
See if the stock bottom end can take it
Do it, just don't put too much timing towards and at peak torque. I would even take timing in the middle and ramp it once torque decays.
  • Like 1
What I was recommending is how to preserve the bottom end by limiting torque, so once you past peak torque you can go nuts with the boost and or timing to make the numbers.
This is a technique good EVO tuners use to stop the pencil conrods snapping with stock EVOs making 300kW+
I will share some results of 8374 1.05 on a 3.2 for comparison. Pity we can't find a way to measure transient response because that seem's to be where these turbo's annihilate others on the market.
  • Like 2
6 hours ago, sneakey pete said:
Pfft, there's no fun in preserving anything though. Full boost as soon as possible, that's the only way!
ahh you see, if you pull timing you'll get boost even sooner with the expense of not reaching MBT for that RPM at that Load point..
Get ECU to log speed, rmp, boost and TPS over time, get to a speed and stand on the throttle.
Ah, thought timing helped with that.
That's why i pay someone to tune my car :P
Note to all.
Finally moved my cam gears on the dyno. Spent 4 hours there yesterday (on a dynocomm inertial - which will soon be eddy brake). I now see what a V-cam would do for you. Moving my Poncam A's closer together (ie-more overlap) yielded undeniable tq gains with no appreciable drop in top end power (my 3" exhaust could be holding me back). I think it liked 8 total degrees of CRANK overlap (2 notches off from '0' on each cam) the best (Advanced intake 4, Retarded exhaust 4), but we did run add another 2 deg (crank) to the intake to bring it to 6 deg intake advance and 4 deg exhaust advance and this is where it stayed (for now). Super choppy idle now, but damn this car pulls like CRAZY now. makes 3 more psi boost at 4k rpms. When I compared 20 psi runs with cams set at 0 the tq goes to the stratosphere. Look at the differences from 4500 rpms to 7k! At 22 psi high number is now 653 whp and 515 wtq but boost control was shakey on these runs (oscillating from 22 down to 18).
It is making 300 WHP at 4k rpms on 20 psi...on 93 octane pumpgas! This is my 8374 EFR .92 IWG on a stock-bore 79mm BC stroker FYI.
  • Like 9
On 20.02.2017 at 2:59 PM, HarrisRacing said:
Note to all.
Power is WHP, so it's about 750HP on engine right? Awesome spool.
This is on 93 octane, what difference can be on 98 octane ? Better spool or power ?
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
