On 4/7/2017 at 2:19 PM, Nismo 3.2ish said:
3.2 Nitto Stroker
HKS Vcam step 2   with UE 260  10.85 Exhaust
EFR8374 , 4" dump into 3 1/2 to tail
8:5 CR
And all the stuff to make it all work together .
I will be giving it my first runaround noon today
6 speed Getrag or 5 speed R32/R33 gearing?
On 08/04/2017 at 5:19 AM, Nismo 3.2ish said:
3.2 Nitto Stroker
8:5 CR
I will be giving it my first runaround noon today :)
Stock R34 GTR/Getrag gearing.
  • Like 1
What he said , twice,  but I think these are the stock ratios
Factory:        6-speed manual
Ratios  :
    3.83, 2.36, 1.69, 1.31, 1.00, 0.79
  • Like 2
Just something to add to that Video that piggy posted of me cruising and winding it on.. I dropped my foot no more than 10mm on the accelerator to maybe near quarter throttle when i filmed that little clip... SUPER IMPRESSIVE STUFF!
If i was going to build a GTR i wouldn't venture outside of what Pete has built.
Though id probably want a taste of a 9180 ?
  • Like 1
Though id probably want a taste of a 9180 [emoji23]
Yep. I'm fighting the 9180 urge daily...but i do think a 8374 is perfect for 2.6-2.8L streetcar.
  • Like 1
Scott said the 9180 would be very good on mine, but I resisted it and went the 8374 and I think the 8374 would also be better on 2.6 or especially the 2.8L street car.
There is one thing I might do later on if the 8474 gets the thumbs up , is do a swap over, but I think I have had enough of mods  ?? LOL
Oh what a crock of shit!
Just get us over again we will find "new mods" for you mate! ?
The modding bug has bitten HARD... Finally got what you desire now its time to fine tune it some more ?
  • Like 2
You found a new mod before you left, the  "Intercooler"  remember :tongue:
How do I say this , PISS OFF!
  • Like 2
I'd say.  Enjoy this now it's finally really stomping from down low and has that snappy EFR response - do the intercooler when you end up getting used to the power and put the EFR8474 on ;)
  • Like 1
57 minutes ago, Buraz said:
Where does everyone buy their EFR's from. Iv been convinced to get one too.
Which turbo are you getting? Turbo dynamics are the cheapest i could find. $2400 including postage and customs for my 7670, i ordered it on Thursday night and it was delivered 8:00am Monday morning. The cheapest i could find in Australia was $2825 + postage.
47 minutes ago, Buraz said:
I'm after an 8374, oh wow that's cheap. Gcg sells them for $3800.
I'll suss out turbo dynamics. Is that aus dollar $2400?
Hit up MTQ. I got Nismo 3.2ish's 8374/1.05 for a tad over $3k, delivered. That was in January. It was 1 of 2 I could find in the country at the time. No one had stock.
I'll give them a call tomorrow Paul, they're 2min from my house!! Didn't know they sold EFR's.
I thought I had a mint package and went all out over last year with everything then the turbo lets me down lol.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
