56 minutes ago, Piggaz said:
Hit up MTQ. I got Nismo 3.2ish's 8374/1.05 for a tad over $3k, delivered. That was in January. It was 1 of 2 I could find in the country at the time. No one had stock.
Hey mate are you messaging MTQ directly? If i follow the links to sonic performance im seeing 3.5k?
Cheers
Maybe they had a price rise?
- The twin gates for starters
- The fab work for the twin gates. Less if you want screamers, more if you want to plumb them in. It's a time consuming job.
- The braided lines to each gate. You can go as basic or as hard as you want here. Single 3 port or duel 4 port MAC valves. The lines are not cheap!
1 hour ago, Buraz said:
I'm after an 8374, oh wow that's cheap. Gcg sells them for $3800.
I'll suss out turbo dynamics. Is that aus dollar $2400?
Hit up Hybrid Turbos, hybrid turbos and turbo dynamics are the same company but turbo dynamics list the 8374 external gate as sold out. :huh:
$2400 Australian dollars for my turbo, the 8374 would be under $3k delivered to your door.
  • Like 3
56 minutes ago, Buraz said:
I'm sold on these!!! Thanks boys I'll make a few calls tomorrow.
If you are not worried about buying from overseas these guys are hard to beat.
http://www.turbozentrum.de/en/turbos-co/borg-warner-efr/efr-8374/borg-warner-efr-8374-twin-scroll-t4/a-28014/
Shipping around AUD150.00 max   all up AUD 2450.00
Bought mine Jan 2015 for AUD 2100  delivered to Japan.
Prices have gone up a little but still cheeeeap!
Food for thought mate and they are good to deal with.
  • Like 1
1 minute ago, Griffin said:
Do the iwg versions make the same numbers as the ewg ones?
I think sub boy made an extra 20 kw by going from a 0.92 to a 1.05 on a 8374/rb30.
  • Like 1
Okay time to chime in here. Thoughts on a 6758 .80 A/R T4 twinscroll on an RB20 with T4 twinscroll manifold? I was thinking 6758 but in the "old EFR thread" people kept banging on about the 7163 being the magic unicorn of the B1 frame size. I'm looking to make a responsive 220-230ish kw on 98 octane and then feed it E85 and make as much power as possible.
I think a 6758 is the best choice unless someone can give me more of an idea about why the 7163 is supposed to be so good?
Thanks
the answer is "it depends" -- engine displacement, boost level, max engine rpm, VE and altitude will all have an effect on backpressure and "the numbers"
Thanks
both are good turbos.  7163 is typically much more popular because when run in twinscroll config -  the spool is similar to 6758 with much more airflow.
1 hour ago, iruvyouskyrine said:
Can anyone offer more info on the 'mixed flow' turbine and it's advantages?
the mixed flow turbine wheel in the 7163 has higher strength and lower inertia than an equivalent radial turbine wheel.  Interestingly the mixed flow aero did not work nearly as well when it was scaled up to the larger wheel sizes
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
