12 minutes ago, SimonR32 said:
I have questions that if answered may cost me a fair bit of money so please don't respond.
Do you have a photo of the turbo on the T88 kit, I also have one but scared of the clearance of the massive EFR?
Do you have a graph from the hubber, although a 9180 on a 2.8L it might give me an indication of similar of a 9174 on a 2.6L?
How can a camera even record at 240p? haha
I posted a graph a page or so ago :) It's kw at all 4 and not all in, he was aiming for 600kw and stopped there for pity for the transmission haha.
Edited by Lithium
Because everyone likes photo's.. this is not my car so details are only 95% accurate.
Nitto 3.2 EFR 8374 1.05 twin EXT gates
~23.5psi back to 21-22 up top on E85
480rwkw (possibly slightly over spinning the turbo but not sure. 6 Speed getrag
  • Like 5
lot of power for 'only' 23 psi
curious to know whats done to head
It's a 3.2. It's going to swallow air alot easier then a 2.6.
Thats 2 3.2/8374's that have returned pretty much the same power for the pressure used.
Got a speed sensor yet?
Turns out Full-Race wanted to share this clip so made an effort and got a higher res version of the 9180 R32 GT-R at Hampton downs, in case people wanted to see it with more than 48 pixels:
2.6ltr or 3ltr?
3.2 should just bring it on earlier.  2.6L should still make same peak power if revved hard enough
My gate pressure was approx 21 psi and mine mad 390kw on JEMs dyno and then 500kw on 31 psi on a freak run (call it 490kw) so it is  roughly 9kw per psi which is why 480rwkw on 23 Surprised me.
Rw to awkw could make  diff.
And no on speed sensor. Been flogging it on 30 psi as it is :)
I didn't know Mr Brooking went single turb......finally got rid of those shite boxe Tomei twins!
.....looks scary, needs more 4wd controller.
Edited by Sub Boy32
  • Like 1
Pay more attention in my group on Facebook sir.  There was a discussion about the potential change, then on a suitable EFR, then dyno results etc :)
  • Like 1
And no on speed sensor. Been flogging it on 30 psi as it is [emoji4]
The 3.2 might be running high compression which would help it make decent power even at relatively mild boost.
My makes over 525kW at 26psi - RB2530 10:1 not running an EFR though.
Fair enough
Finally got my hands on a 34 GTR tail shaft.
Going to do the 34 GETRAG conversion while retaining r33 GTR diff gears for even shorter gear ratios.
8374 with even shorter ratios = super responsive street car :D
Come to our next track day in September, real men race on the track not the street :)
  • Like 1
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
