32 minutes ago, Dale FZ1 said:
Some pics on the WG placement and pipe angles would  be a big help for people to understand what's the problem.  Bench testing the gate for correct function and all intact would also be a good idea.
Pretty sure most of us are guilty of failing to review/check ALL the basics when something doesn't seem to work as it should.
LOL!  I have been trying to put my response together in fits and starts for the last hour or so, this is very much what I was thinking when I wrote mine two.   Very much agree with this, I've been here done that myself.
It's a 6boost T4 TS Manifold with a 50mm external gate on it. I think the merge is pretty shitful to be honest, but again, not the only one running a gate in this manner.
I am using the BOV internal to the EFR itself
I attached a picture of my exhaust merge. It is a 3in from the dump, and 2in from the wastegate that merge into the 3.5 section after the cat.
I have used this with the controller off. I had all of this setup in the past with a GTX3582 making 420+ through the auto and downsized to use a smaller turbo with the EFR. I was able to run as low as 4psi with the GTX3582 with a gate off the turbine housing, so I know the controller works/is disabled when everything is zeroed out.
I did get boost spikes back then too, way way WAY worse, which I had assumed happened when loading up the car through the converter in a high gear.
But now manual, now EFR, similar problem. Trying to run low (18psi) boost is some tiny amount of duty cycle, which I can only assume is a byproduct of 1.05 housing and 2.8 and a small compressor.
The 5 port I have because I've always had it. Scottynm35 provided it way back in the day. The only difference I can see is that it has 2 exhaust ports instead of 1 - It still runs off 2 wires like any other boost controller connected to a Haltech PS2000.
I suspect it's setup related, that the gate angle is just crap and a "big" motor spinning a "small" turbo on sharp opening of throttle, perhaps a little 'worse' given how responsive/transient the EFR is.
nice exhaust system :)
looks like a few people with the same idea as I had initially.. still a cat in there?
Can you post up a log from the halaltech when you come on boost say in 3rd or 2nd, etc.? I suspect could be timing related as there's a table that allows you to retard timing as you come on/off the throttle to make the transients smoother.
Yes, it's running a 5in cat in there.
I can try and post a log, but it'd be a day or so or two or three weeks before doing that because not so easy to organize such a run lol.
However there is no table for transient timing advance on the PS2000. So the timing is going to be what the base map is specifying.
I did get boost spikes back then too, way way WAY worse, which I had assumed happened when loading up the car through the converter in a high gear.But now manual, now EFR, similar problem.
Firstly, that plumb back merge does look good.
But, I agree with your assessment on the WG angle.  Gas has mass.  And if it's highly energised pressure pulses trying to change direction rapidly, not going to happen easily.  Workmanship on the 6boob manifold is no problem, but that WG design doesn't look right (to me) with a short hard 90 straight off the collector, not going generally with the direction of flow first. Reckon I would be doing some re-engineering there.
Does it currently have a divider right up to the WG valve? Twin scroll, needs completely separate gas flow paths.
Is there an inline restrictor for the MAC plumbing?  This is where you make the thing really sensitive to duty cycle changes.  I have used a 1.2mm MIG tip to great effect many times in plumbing MAC valves, cheap too.  A novice error I have made twice is to have the ports connected to the wrong nipples. Worth knowing.
From comments, there's a historical problem showing even with a different turbine/WG setup. Presuming you've used the same tuner, and approach to tuning.  Could be a basic error there, require a second set of eyes over the tune file to see if things are all good there. (Suggestion is directed towards problem identification, not blaming or flaming individuals)
Edited by Dale FZ1
Hey guys, just wanting to confirm the routing of the BOV vacuum line, are the old charcoal cansiter hard lines appropriate for this? I've seen a few others that look like they've done it that way - it also looks a lot tidier. Let me know if there's a better way to do it!
I remember SAU VIC pres Tony's red 33 having boost control issues, and for 300+kw required 2x large waste gates just to get it out. This was all under Racepace tuning/instruction. I don't know where they installed it, but apparently did the trick (though they don't use electronic boost control, but I won't delve into that...)
Alright I did some more testing as promised, and you can see what the logs look like below.
First three small runs I had the controller setup as a 4 port mac.
Last two I disconnected the top hose, so boost isn't being fed into the top chamber. As you can see there's more duty cycle there from the controller - So that may be just inducing a small boost leak into the system.
In any case you can see how the controller does drop off from 100% to ~20% duty cycle, there's clearly a delay and a spike.
This is with the controller being told to stop going 100% 6psi before hitting target boost, which is 18psi.
Note: These pulls were in 3rd gear. The first 3 were up a big hill, (obviously me backing off as boost was spiking out of control) as was the last one.
I moved the source for controller from my charge pipe just before intake, to the compressor housing, but it doesn't seem to have made much difference in terms of responding quicker.
boost.csv
Would have been good without the ECU boost control turned on so we know if we are dealing with a mechanical boost control problem.  This makes it look a lot like a tuning issue - if I were tuning it the first thing I would be doing is getting a baseline with purely mechanical boost control to know with certainty where I should be looking.  We could go around in circles with ECU setting discussions if it's mechanical, and alternately trying to work out what is going with the mechanical side of thing with data skewed by quite a lot of ECU influence makes the data hard to draw any meaning from
Edited by Lithium
  • Like 2
It's possible from that chart a combination from too light WG spring + too much preload+ lots of backpressure.  Purely guessing from the other side of the planet and not aware of your setup ?
Edit I see the 6boost above which turbo and housing is this
Edited by Full-Race Geoff
This morning I did exactly that, and run a line directly from the compressor housing and the bottom port of the 50mm gate.
Drove to work, will post logs when I do some actual testing. Response felt about the same and it made 12psi pretty solidly, at least as much as you can see "solidly" when looking at a gauge and not at the road.
Just for Geoff, it's a 7670 with a 1.05 rear on a 2.8 with VCT. The housing is really massive. The below picture is a comparison betrween the EFR (bottom obviously) and a GTX3582 with a .82 rear.
Sweet - so yet to be confirmed, but probably not the turbo/setup itself so much as how the ECU boost control is setup then.  Here's hoping that's the case, it'll be a lot cheaper/easier to resolve :)
I see you are using a 50mm waste gate.
Is that a turbosmart progate or progate lite?
The lite version is unsuitable for 4 port boost control in my opinion. I would only consider using it if nothing else would fit. The diaphragm to valve area is only around 1.3 so is more susceptable to manifold pressure differences with a light spring.
The real progate 50 has a diaphragm to valve area of around 2 so has much better control.
Edited by burn4005
It's a full progate.
As more testing unfolds (i.e line directly to gate) it's starting to really look like the boost threshold is something I have to live with. It will spike when running directly between compressor housing and bottom port of wastegate with nothing else attached.
When it wants to spin up it really will spin up. Suppose it's just a compromise from choosing the setup I ended up choosing. Looking at the exhaust housings back to back is pretty telling, and I chose the turbo so it wouldn't be maxxed out/overheated/choked etc, so I ended having that at the expense of less power and more lag relative to the Garrett Option ;)
With 0% duty cycle it (boost) behaves the same as being connected directly to the turbo with nothing in the middle of it. This will cause boost to come on full at about 4500rpm (3rd) and peak at 15psi, I've then fed in duty cycle to continue it to climb up to about 19.
I'd change the housing at the rear, but there is no housing to change to. Being RWD perhaps there's not much sense having 20psi at 3000RPM anyhow.. car feels pretty planted and on the edge of slip all the way through the rev range so I suppose that's also good.
Still think the 7670 EWG (1.05) would be bad news on a 2.5 with that housing though. OFC if someone buys one and has wildly excellent results then I'll go hunting for fixes again :P
Having a look at a 9174 (when they were all bought) the rear of the 7670 1.05 is actually basically the same damn size. I am sure at this point an 8374 would do what the 7670 does but with just more power tbh. The delivery of the thing belies its "lag" as it really does just get on boost and keep pulling in a very linear, very stable very unrelenting fashion. There's no power skids here (almost, though!) and personally I like that. If I did have monster midrange, I would have setup boost by gear to effectively create what I currently have.
The target was always about 350kw running moderately lazy because I have melted manifolds and rear housings in the past at the track - so I suppose I have this and it fits the bill. It just feels a bit agricultural to be using open loop, but in the grand scheme of things I had to control the controller manually to get the result.
Will have a dyno result in about 3 weeks when it goes there and shall test the accuracy of my butt dyno.
it's just a compromise from choosing the setup I ended up choosing.  I chose the turbo so it wouldn't be maxxed out/overheated/choked etc, so I ended having that at the expense of less power and more lag relative to the Garrett Option
My first response is that NO setup is going to be the "silver bullet" for performance.  It's only about achieving an acceptable compromise.  It's always been amazing to review logs for how an engine behaves on-road (or track) and see how different that is compared to a dyno.  What you've got isn't necessarily bad, but with the spiking there's room to make it less wrong.
Secondly, the big thing (for me) is how does it feel? And can the chassis setup (which includes tyres) actually use it without just turning rubber to smoke?  Edits ^^ from your post sort of indicate that you're actually in "about" the right performance area for a 2wd R chassis. Without the cheater traction advantage of a GTR, it's pointless IMO to try to emulate/expect the same sort of engine performance as a GTR because it probably won't work to best effect.
https://www.sau.com.au/forums/topic/358438-34geeteetee-daily-track-project/?page=111
Have a look at what Mat has achieved with the 8374 on a 25 Neo.  And look closely at the WG takeoff angles.  Now he has no issues with boost control, but the target in that instance is going to be North of 20psi so direct comparisons aren't possible if you are for some reason targeting 15psi (arbitrary figure chosen).
Perhaps Mat could offer experiences/opinions regarding the 8374 on an RB25, and his take on what applications that would best suit and/or what compromises would have to be accepted.  Bear in mind it's experiences from a guy who's actually achieving some pretty solid results without major dramas.
** Somewhere in amongst this, I'm seeing that we are fixating on boost pressure as the measure of turbocharger control.  There is enough tech available in Greg's setup that perhaps turbo speed is where the thoughts are best focused** :)
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
