Intake 6 deg advanced. Ex 4 retard. I have tried a few different settings but it always likes 10 deg of overlap the best. Turbo comes on strongest there and makes best overall power band. Did everything from no overlap to 20 deg overlap...10 is best but there are good gains in the 6-10 range if you are worried about idle quality. Also 8 deg intake advance and 2 deg ex retard made similar power. Power drops over 10 deg though.
It will hit 700 whp tonight. I regapped my bcpr8es plugs down to .020" to fight high boost breakup. Yes turbo is really spinning but it's 41 deg F here today so it's still relatively low rpms to move the air.
Boom. Check them digits out. Sucker woke up at 30 psi in the midrange. 26 on top. 20171208_222058.jpg
  • Like 2
American dyno is bloody awesome
I guarantee this car has high 130's if not mid 140's in it. It is flat out scary to drive...recall I ran 128mph on pump 93 (your ron98) on 18-19 psi boost in the 1/4 and it pales in comparison to how it is now. It is an absolute ANIMAL...
You'd wanna be pulling mid 140s to back up 740hp ?
Gunna repeat myself here... But the 8374 is a BEAST of a snail!
Driven 3 8374 cars ranging from 2.8L - 3.2L and it really makes my tip drip! ?
Don't mind me, that was just an observation on the figure differences from Aus VS USA. It wasn't meant to add or detract from your comments.
  • Like 1
Anyone here got a source on 90 deg compressor covers for the 7670? I thought this was the B2 frame, though it looks like the outlet of the 8374 is 2.5in, and the 7670 is 2in, can't seem to find an "OEM" style fix for this.
Would appreciate something less agricultural than simply welding a 90 degree on literally in a backyard. Given the outlet is VERY close to the 6boost manifold runners Silcon is only going to last so long. So long in this case meaning it died yesterday and I doubt very much that the heat shielding aluminum stuff I put around it is going to keep it alive.
Yeah, glad you said that - I start rolling my eyes a bit when people make comments that "If it was a real 700+whp then it'd run xxxmph".... fact of the matter is dynos are just tuning tools and it's not that American dynos are happy, it's that MOST Australian dynos read lower than what pretty much everyone else in the world use unless they have imported a Dyno Dynamics dyno.   740whp sounds about right for high 130mph/around 140mph to me from the Dynapacks that I am used to, and sounds about right for what an EFR8374 is capable of.  I'm guessing if this dyno reads like what I am used to then the turbo will be within safe rpm, JUST.
Nice result, I look forward to hearing how it goes - E85 is awesome, tends to make the car feel better in general ... not just when tracing the target boost curve.  Been good seeing this setup gradually be refined and start showing what the EFR8374 is capable of on a nice RB :)
  • Like 1
not sure if that worked or not ?
link below
Edited by VFRegal
Run in tune complete on my thing, these turbos are amazing - feels like my old -5 setup but with an extra 200kw and 2psi less boost.
engine spec,
2.8L,
1mm O/S valves,
Tomei sized inlet ports,
CPC carbon plenum matched up to the big ports
6boost, 60mm turboSmart Gate
Spline drive Tomei Pump
Platinum race engines Block Brace
Race Pace Sump
R35 Coils
Ross Crank Trigger
Haltech 2500
9180 1.05
26psi 500kw
  • Like 3
engine spec,
2.8L,
1mm O/S valves,
Race Pace Sump
R35 Coils
Ross Crank Trigger
Haltech 2500
9180 1.05
26psi 500kw
Awesome graph and power/response! ima sure it would drive better than it looks on paper! (i was also comparing ur graph to my T04z dyno sheet, obviously your EFR has improvement everywhere hahahha)
Ima also looking at upgrades now so may I please ask why 6boost single wastegate instead of twin wastegates? Prob cheaper, but wouldn't twin wastegates be more ideal?
engine spec,
2.8L,
1mm O/S valves,
Race Pace Sump
R35 Coils
Ross Crank Trigger
Haltech 2500
9180 1.05
26psi 500kw
Looks like it would be mega fun to drive, I wonder if the million dollar plenum was worth the investment. (besides the fact it looks good).
the plenum is deff not worth the investment the amount of work invloved and extra lines and hoses needed to be made/brought to set it up, it should make 500kw in NA form. The plenum's are a waste, Nismo FTW.
I went 60mm single gate, for packaging as theres not alot of room under there for 2 gates. Also the waste gate pipe is split anyway so you get the same effect with the single gate just less mucking around.
  • Like 2
I looked at that option but after my 6Boob experience i chose to go down the path of the HypeEx/Fabtech true twin scroll manifold with twin gates... He performed artwork on it and it all fits pretty well! Going to be a prick to take off over the next few weeks so i can get the engine out for a build.
Will be interesting to overlay the graphs once i get mine running ;)
  • Like 2
Yeah so true 2 gates would be alot more packed and costs more (altho $ doesnt seem like a matter to you =P)
Does the wastegate pipe split came standard in the 6boost single gate???
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
