Borg Warner EFR Series Turbo's V 2.0
Piggaz
Intake 6 deg advanced. Ex 4 retard. I have tried a few different settings but it always likes 10 deg of overlap the best. Turbo comes on strongest there and makes best overall power band. Did everything from no overlap to 20 deg overlap...10 is best but there are good gains in the 6-10 range if you are worried about idle quality. Also 8 deg intake advance and 2 deg ex retard made similar power. Power drops over 10 deg though.
It will hit 700 whp tonight. I regapped my bcpr8es plugs down to .020" to fight high boost breakup. Yes turbo is really spinning but it's 41 deg F here today so it's still relatively low rpms to move the air.
Boom. Check them digits out. Sucker woke up at 30 psi in the midrange. 26 on top. 20171208_222058.jpg
  • Like 2
American dyno is bloody awesome
I guarantee this car has high 130's if not mid 140's in it. It is flat out scary to drive...recall I ran 128mph on pump 93 (your ron98) on 18-19 psi boost in the 1/4 and it pales in comparison to how it is now. It is an absolute ANIMAL...
You'd wanna be pulling mid 140s to back up 740hp ?
Gunna repeat myself here... But the 8374 is a BEAST of a snail!
Driven 3 8374 cars ranging from 2.8L - 3.2L and it really makes my tip drip! ?
Don't mind me, that was just an observation on the figure differences from Aus VS USA. It wasn't meant to add or detract from your comments.
  • Like 1
Anyone here got a source on 90 deg compressor covers for the 7670? I thought this was the B2 frame, though it looks like the outlet of the 8374 is 2.5in, and the 7670 is 2in, can't seem to find an "OEM" style fix for this.
Would appreciate something less agricultural than simply welding a 90 degree on literally in a backyard. Given the outlet is VERY close to the 6boost manifold runners Silcon is only going to last so long. So long in this case meaning it died yesterday and I doubt very much that the heat shielding aluminum stuff I put around it is going to keep it alive.
Yeah, glad you said that - I start rolling my eyes a bit when people make comments that "If it was a real 700+whp then it'd run xxxmph".... fact of the matter is dynos are just tuning tools and it's not that American dynos are happy, it's that MOST Australian dynos read lower than what pretty much everyone else in the world use unless they have imported a Dyno Dynamics dyno.   740whp sounds about right for high 130mph/around 140mph to me from the Dynapacks that I am used to, and sounds about right for what an EFR8374 is capable of.  I'm guessing if this dyno reads like what I am used to then the turbo will be within safe rpm, JUST.
Nice result, I look forward to hearing how it goes - E85 is awesome, tends to make the car feel better in general ... not just when tracing the target boost curve.  Been good seeing this setup gradually be refined and start showing what the EFR8374 is capable of on a nice RB :)
  • Like 1
not sure if that worked or not ?
link below
Edited by VFRegal
Run in tune complete on my thing, these turbos are amazing - feels like my old -5 setup but with an extra 200kw and 2psi less boost.
engine spec,
2.8L,
1mm O/S valves,
Tomei sized inlet ports,
CPC carbon plenum matched up to the big ports
6boost, 60mm turboSmart Gate
Spline drive Tomei Pump
Platinum race engines Block Brace
Race Pace Sump
R35 Coils
Ross Crank Trigger
Haltech 2500
9180 1.05
26psi 500kw
  • Like 3
engine spec,
2.8L,
1mm O/S valves,
Race Pace Sump
R35 Coils
Ross Crank Trigger
Haltech 2500
9180 1.05
26psi 500kw
Awesome graph and power/response! ima sure it would drive better than it looks on paper! (i was also comparing ur graph to my T04z dyno sheet, obviously your EFR has improvement everywhere hahahha)
Ima also looking at upgrades now so may I please ask why 6boost single wastegate instead of twin wastegates? Prob cheaper, but wouldn't twin wastegates be more ideal?
engine spec,
2.8L,
1mm O/S valves,
Race Pace Sump
R35 Coils
Ross Crank Trigger
Haltech 2500
9180 1.05
26psi 500kw
Looks like it would be mega fun to drive, I wonder if the million dollar plenum was worth the investment. (besides the fact it looks good).
the plenum is deff not worth the investment the amount of work invloved and extra lines and hoses needed to be made/brought to set it up, it should make 500kw in NA form. The plenum's are a waste, Nismo FTW.
I went 60mm single gate, for packaging as theres not alot of room under there for 2 gates. Also the waste gate pipe is split anyway so you get the same effect with the single gate just less mucking around.
  • Like 2
I looked at that option but after my 6Boob experience i chose to go down the path of the HypeEx/Fabtech true twin scroll manifold with twin gates... He performed artwork on it and it all fits pretty well! Going to be a prick to take off over the next few weeks so i can get the engine out for a build.
Will be interesting to overlay the graphs once i get mine running ;)
  • Like 2
Yeah so true 2 gates would be alot more packed and costs more (altho $ doesnt seem like a matter to you =P)
Does the wastegate pipe split came standard in the 6boost single gate???
    • There are a few variables here, some are relevant but not critical (IMHO) to help answer your question. The two major things: 1) Ignoring anything to do with forced induction - all engines have their own natural torque curve, and it will ALWAYS roll over higher in the rpm.  There is a fixed relationship between power and torque.  When dealing with kw and nm, the relationship between them is roughly: kw = (rpm * nm) / 9549 nm = (kw / rpm) * 9549 The peak torque of an engine (without boost) will typically climb until somewhere nearish the middle of it's operating rev range, give or take a bit - then start dropping again.   The nearer the minimum and maximum rpm of the engine the steeper that drop off tends to be. 2) Boost simply increases the density of the air going into the engine, which inflates the torque at that point.  The ramp up in the torque curve you see on a turbo engine is due to the boost rising, but it's essentially just multiplying the torque you'd see if it was naturally aspirated.  The roll over you see at the end will typically be what would have always happened with the engine, whether it was naturally aspirated or turbocharged.   If the torque never started dropping then power would climb infinitely. The cool thing about this is you absolutely can tune the power delivery to suit the needs of the owner and/or the limitations of the car, and I regularly do this.    With modern turbos we've got to the point where a setup that someone may run well over 20psi of boost with could actually reach target boost well under 4000rpm if the tuner/owner WANTED to - and a lot of people seem to do this when there is actually no realistic benefit, generally it just adds a massive amount of strain to the engine and drivetrain and often actually makes the car harder to drive. As a general rule I tend to tune the boost curves for cars I tune to reach a "useful" torque level through the rev range and will often end up with a curve that ramps hard to a point, then creeps for the rest of the rev range - not to make the boost curve "soft" as such, but more to make sure its neither laggy nor pointlessly violent in it's delivery.   There have been cars I've tuned to be almost like a centrifugal supercharger (or naturally-aspirated-ish) where they actually only hit like 8psi of boost before opening the gate, then ramp up the next 10psi over the rev range... if the car is "loose enough" to drive. On the flip side I've tuned a car that had stock cams and the engine's natural torque curve fell over HARD in the higher rpm and resulted in a slightly awkward power curve to work with, in that case I actually started ramping up boost to boost torque in a way to offset the engines "NA" torque drop off... at peak rpm actually running a good 5psi+ more boost that what the "flat curve" would have defined.  This gave the owner an extra 500rpm or so of useable rev range, and had a fairly solid impact on times he was running at motorsport events due to being able to hold gears a bit longer and also falling into a more useful part of the rev range in the following gears. Here's an example of an RB in a GTSt I've done the "softened" boost curve to not pointlessly ramp straight to the max boost target early in the rpm, but still made sure it builds useful boost.  If you went in the car you'd not guess at all that the boost curve was doing anything "weird", it feels like it spools immediately and accelerates relentlessly (traction dependent) and holds to max rpm.   I don't know if you'd guess what the boost curve was doing by driving the car, or even looking at the dyno plot... but imho it suits the combination.
    • therefore on the first examples, as we see, changing cams (graph 2) influences the quantity of torque at high revs its OK for me. so a tuner can act on the wastegate via the boost controller to increase the boost at high revs? on the last example, the boost does not decrease ok, but the torque does. this can come from cams etc etc ok. but on the other curves the boost is not constant, it increases, this is what I find strange to my mind. even more so if it comes from the relief valve. sorry I'm very new don't blame me. in my mind I couldn't imagine how the boost could be higher after the spool
    • right, but fundamentally, for a given mechanical setup, you are either using all the torque (and therefore power) it will give, or you are choosing to run it less efficiently. Many tuners will have a practice of identifying peak available torque and then winding it back a couple of % for safety, but unless you are working around a very specific issue like a weak gearbox, there is nothing to be gained by making 20 or 30% less than the engine can
    • You can manipulate the torque delivery by ramping in boost gently, then throwing it all in after peak torque to keep the torque flat. It's nothing magical.
    • Tuning the wastegate to do it. That is all. Most people want the boost to not fall off like the most recent example. Those also look like dyno runs with an Auto/Torque converter setup, which does fun things to the graph. The boost tapers down like that because the turbo cannot supply the same amount of air at 7000rpm that it can at 3000 in terms of PSI. That, or the tuner has decided that it tapering off like that is what someone chose to do. IF you have a wastegate that can't bleed enough air to slow the turbine, and IF that turbo can flow enough air to feed the engine at high RPM, you get 'boost creep' which is a rise of boost pressure beyond what you are capable of controlling and/or want. None of these show symptoms of that, but if you had a run that was 20psi at 3000rpm, and 27psi at 7000rpm, it could be an example of that. Or simply that the person wanted boost later for their own reasons... The dyno graphs don't always show the full context.
