3 minutes ago, GTSBoy said:
It needs to, otherwise there is zero point in making the manifold split pulse.
I was going the single gate route but got talked out of it.... No regrets!
  • Like 1
Won't quote names but I've seen a few from big brands appear to be split until both pulses are just going into 1x big 50 mm hole to the gate.
Best I've seen from one brand was an open scroll manifold with a divided T3 flange welded on top lol
  • Haha 1
yeah 6 boost did the spilt for the gate.
I did all the fab work, trust me you dont want anymore pipe work under there. In saying that my gate is plumbed back in which makes it a bit harder. Screamer pipes are easier to route.
But at the end of the day, what for - why make it harder and most $$$ for the same result.
Edited by Deano 1
  • Like 2
Also the plate thats welded up the inside of the pipe from the mani to gate flange - Hangs out past the end of the pipe, once you weld the V band onto the end of the pipe - you than shape the "spilt plate" to suit the back of the waste gate, so its sealed up.
  • Like 1
This would be practically no different to the IWG housings, and i'd be pretty confident that it would be as good as twin gates.
What stumps me is when people do have a split pulse manifold and the single gate isn't divided..
  • Like 1
Given r32-25t has posted a dyno of his -5's with vcam on the same dyno presumably as this i thought i'd put them together for interests stake.
Of course if ramp rate was different etc might cause comparison issues but i figure this is better than most considering its same dyno and a short period of time apart.
  • Like 4
For what its worth, going on boost curves etc, i'd expect my 2.8/9.5:1 8374 to be to the left of the -5 curve. But its hard to say if street feel would line up on a dyno etc.
But yes if i had another spare 5000 i'd get vcam.
Your car would belt the 5s just like every other back to back 5s vs 8374.
Plus a run in tune would be low on timing I'd like to think which should fatten up the middle a bit more.
V cam on your car would probably just induce surge. With the hi comp and .92 it wouldn't need any help getting it spooling!
Piggies car would start surging on the dyno as low as 2800rpm.
So even if it had v cam on it, you couldn’t move the intake cam anyways.
Edited by Mick_o
New EFR crew member checking in....
Manifold will be a 6boost w/ twin gates.
Wastegates will be tial mv-s.
Exhaust will be plumbed back via 3.5" downpipe
The EFR will be used on a SR20DET with a fully ported NAPREC head, big valve chamber with deleted squish pads.
ETA for completion is probably 6 months away.
Having been in a 2.8L EFR machine, the thing is completely mental and beats stock response with quadruple the power.  THEY ARE MAGIC fellas.
  • Like 1
21 minutes ago, sneakey pete said:
might plot that tomorrow arvo if i get a chance.
Note the one i already plotted was -5's with vcam.
As the pig said thats also the same v cam and rolling road not hub dyno like the -5 result. So theres a possibility that its a "higher reading" vs the rollers.
Tell em the turbo son!
Because I was worried about the exact same thing I spoke to Jez about that and his dynos are within 3% of each other
Sweet thanks for clearing that up ?
So lets call it "on par" you're at about 160kw at 4000.. The 8374 is at about 240kw at 4000??
80kw through the middle with 60kw up top.
Thats quite alot more power EVERYWHERE!
Plus all those nice things EFR delivers that the dynosheet doesn't show...
Edited by Mick_o
I'm happy with mine also but coming from Tomei ARMS that wouldn't be a glowing endorsement :P
did take it for a bit of a moutain squirt last week and its great, no 'to large to be fun' issues... and (once i get e85/boost) will have a shitload of power for whenever else i want it
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
