He was a low mount twins man before,  was a bit shocked at how much power and torque it made so effortlessly - it still is running a stock gearbox so I doubt he will be winding it up until or if that is resolved.  The car is "real world" FAST now so having headroom in the setup is no liability :)
Results from that round of superlap - his fastest time was the one in the video which was clearly not clean, it started raining afterwards and he called it for the weekend but then it dried out later and others kept going... he probably had more time in it.
His car is the R32 in the Pro-Street class below (Tony Satherly/Mitsi EVO in Pro Open is the 666 EVO which went sub 1:30s at WTAC 2017)
No automatic alt text available.
  • Like 2
Mine (8374 on rb26) just got a shiny new KV8 and an EMAP sensor so tune will be early february.
I'm pretty close to deciding to throw an E46 M3 DBW motor on it with an R35 pedal, but might do that a bit later in the year as there are some CAD shenanigans and machine work required for that to work.
I'm interested in how the PPS boost target, torque demand and actual TPS position will correlate when they can all be independently set.
Above in the orange is one of my aborted run at ~22psi on the 7670. Splitfires called it quits and the Dyno got mostly reconfigured as it was dummied up in the past as a 4.36 ratio because of the slip of the auto converter. It's now 4.1 (my rear diff is 4.083 but it's 0.5% difference).
VCT is now actually working and wired in. The car made 330kw at 12psi, and the best run before we gave up was 433kw at 5700rpm before spark breakdown (again at 23psi). (Not pictured in graph above)
No, I didn't get printouts because spent more time actually tuning the car through various boost levels between 12 and 20psi as that whole section before VCT switched off (i.e 1100 to 5500rpm) was REALLY LEAN as VCT hadn't been running..... for years...
In any case, big turbo is big. I still maintain this thing is a lot closer to the 8374 than most realise. It was still picking up more than 10kw per PSI on my motor going from 330 @ 12 to what would have been over 433kw at 22-23psi.
  • Like 3
1 hour ago, Piggaz said:
Are you going pre/post throttle MAP sensors with the KV8?
yea the plan is to get one of those 4 bar map/IAT sensors welded into the top of the intake manifold.. I think. depends if it can be welded in-situ or not. otherwise will just run a 4 bar from one of the original boost ports near cyl 6, but would rather not due to cyl 6 not being a good representation of all the cylinders intake pressures.
will initially tune on just TPS with a Map correction table and do some logging see what will work the best. my fuel model has all the corrections enabled (charge temp, injector delta, Exhaust pressure correction, fuel density etc. have made charge temp offset table that works like the fuel cooling coefficient in Motec M1 and Link ECUs too, that blends for Ethanol. cooling offset = coefficient/lambda target.. coeff is about 14 deg for 98 and 20 deg for E85.
have spoken to Scott at emtron at length about best strategies for ITB turbo and it looks like a blend from modelled throttle mass flow to straight speed density MAP at about ~85% throttle will be a good crossover, but there will be a dead spot somewhere between the two where the throttle model isnt entirely accurate any more, and the MAP model isn't 100% either so will be tricky to get exactly right.
Edited by burn4005
I’m running pre/post MAP sensors and didn’t have to drill and tap anything. It can be done.
Short little hoses to the source.
1 minute ago, burn4005 said:
what are you using as pre-throttle map source?
Have to ask Scott, he overseen it all. (The car isn’t at home at the moment). His whole thing was to have the hoses as short as possible/not have a MAP sensor on the board with 2 meters of vacuum hose running inside the cabin.
interesting. I've got a long Map hose to dampen the post ITB signal down.. i guess he'd rather use the digital filtering instead.
my other idea in progress is a pressure sensor on the clutch line, which will correlate pretty closely to clamp force.
should be able to get launches and flat shifting dialed in (ITB will allow auto throttle blipping too for downshifts)
Edited by burn4005
3 minutes ago, burn4005 said:
its impossible to manually blip for downshifts on a paddle shift when you have gear stacking.
My bad, I didn't realize you were going full time attack spec with paddle shift etc
I just used one of the nipples of the under plenum box and ran a short cable to the map sensor i've mounted to the old fuel line mounts under the plenum, does the trick and is tidy and short. Not sure that the quality of the signal has been any issue either, plus i'd imagine its pretty even as its coming from the balance tube via two points.
How does VCT not running “for years” NOT get noticed? How does a car get let out the door “for years” with VCT not working? Who tunes this thing? They should be sacked! That’s so far BELOW apart! What else is wrong with the setup?
The 7670 is not this “big Monster” snail and CANNOT be compared to a 8374. It’s 64 lb/min vs 79 lb/ min.
The Evo 9 guys go from a stock snail, whack a 7670/1.05 on and they say it drives like the factory turbo.
My 2.8 Static cam/8374/1.05 is “all in” at 3500 RPM in second. Your 2.8/VCT/7670 should be WELL earlier than that! Something is wrong!
  • Like 1
So much that! ^^^
My mate has a stock block Evo 9 with a 7670 1.05 rear and his car behaves like a 54lb bolt on Evo turbo.
I cant possibly see how a 64lb snail behaves like a 79lb turbo?
They arent even in the same realm!
Id also like to know if you have been in a 8374 powered car to make this comparison?
28 minutes ago, sneakey pete said:
Not sure why mines 700rpm later with the same cams
Guess more tuning will help a little.
How modified is your head?
How big is your exhaust?
Where are the cams set? (Mine are 0/0)
Finalise the tune and see what happens.
Whats holding the final tune up? It’s been ages!
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
