4 hours ago, Piggaz said:
Do you plan on building this soon? How hard do you rev it? Any other changes apart from the snail?
Its gonna be interesting to see the difference, especially in the real world.
Still on the factory gearbox?
Will build when it pops.  Probably rev to 8500.
It has getrag behind it now with diff. No other changes to motor aside from turbo.
Do you at least have decent headstuds? the OEM ones are known to stretch and lift heads
yes. head gasket, studs, springs, valves etc etc have been upgraded. Basic stuff is done
Edited by usmair
  • Like 1
On 05/02/2018 at 8:31 PM, usmair said:
I ended up with 1.05 as it didnt look like the 1.45 would fit on current mani.
Should be on this week with tune next week or so.
Nice, I don't really think the 1.05 should be a show stopper at all - especially on a "mild" 2.6, I'd say the turbine speed would be the key thing to keep an eye on.  Very interested to see what the difference is from the 1.05 EFR8374!
Good luck :)
After reading through this thread you all convinced me to not get a Garrett GTX3582R and instead I just purchased purchased a efr8374 1.05 ex gate from gcg turbos yesterday. Also brought a 6boost split pulse manifold and 50mm turbosmart pro gate.
Can’t wait to institute in the coming weeks.
  • Like 2
Guys, what do you think the below setup? Would it be laggy?
1. efr9180 1.05
2. Fullrace manifold running twin gates
3. Rb26 87mm forged CP piston 9:1 compression with tomei rods
4. Ported head with tomei type b cams
5. Greddy intake
6. Getrag with 4.1 final drives
I hv been searching for results of 9180 on stock 2.6l displacement but couldnt find much info.  what i am really after is whether it is going to be laggy.
Fuel will be 97 but running on wmi.
Thanks
From guys that have gone from -5’s/2530’s to a 9180/1.05, it behaves like a pair of -5’s to 4000 rpm then the 9180 will walk away from it.
If an 8374/1.05 is on 500 rpm earlier than a pair of -5’s then how much later can a 9180 be?
*using -5’s as a yard stick.
How hard will you be leaning on it?
It won’t be the most responsive setup in the world but you are talking about a 94 lb/minute turbo all in.
1. efr9180 1.05
5. Greddy intake
Thanks
30psi by 5000rpmish. Will have actual results next week
  • Like 1
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
