So, a long long time since I posted on SAU, and my eyes glazed over a long long way back in this thread.
Here is the bones of it, I have had my track car off track for nearly three years for a full wiring and electronics refresh (Wiring, PDM, dash, ECU) and as usual time and money had their way. Long story short I hope to have the car running again in the next month or so.
The car has a GT2860RS (.64 exhaust housing) on a redtop RB20DET making 208RWKW on 98 RON at 18PSI while being nice and snappy for the usual uses of the car, short tracks with slow corners and hillclimbs. The turbo is on one of those horrid little T3 to T25 adapters on the standard manifold and I would love to get rid of it.
I know the RB20 in any guise is getting long in the tooth but have people had much success with the EFR turbos on these? The only advice I have had is "Go a size bigger than you think'. What I would love is if the newer design would give me the same kind of small turbo responsiveness without choking it as much at higher revs.
My biggest wants on a conversion would be marginal to no loss of lower rev range performance, T3 bolt on (Unless the T3 to T4 adapters are a better thing than the two part T3 to T25 ones) and after that a bit of an extension of higher RPM capability. Am I dreaming?
My other thought was to build an adapter to take it to a V band turbine and fit the .72 A/R housing and an external gate.
Hey Blue,
I've got an EFR7163 on an SR20DET, so not too dissimilar setup. I am running e85, and have had a couple of issues with back pressure with a T4 TS mani and internal gate.
I can certainly attest to the response with a 'big' 7163 on a 2 litre. I'm running 307rwkw currently and making 250rwkw at 4000rpm. I have VCT, fairly small cams and as I said e85 so all that will help a little with response.
There's no T3 options in the EFR range (that I've seen). So you're on t25, vband or T4. I would think a 7163 in vband (the largest rear, which is a good thing for these) and external gate would be the way to go. Hard to say without knowing exactly how responsive your current turbo is. I would think 98 and ext gate would net you near 280rwkw and only lose a 'little' in response (compared to mine). FYI I'm not super familiar with RB20 setups.
For anyone else who had any interest in my setup / results I have some weirdness with my Nistune ECU and the HPX AFM. VCT is also rattling a little and getting tired. And can't really hold boost with internal gate. I'll probably switch to Haltech ECU for boost control, MAP sensor, OBD gauges, engine protection based on turbo speed rpm and a few other things. Hopefully that'll iron out some of the current bugs. Otherwise I'll just say f**k it and grab 2 x 38mm gates and go external setup which SHOULD get around the boost holding issue.
  • Like 1
Also Blue, the devil's advocate in me wants to also maybe suggest one of the new G25-550 Garret turbos. They come in a T25 with 0.49" rear which by the looks of their specs would get you a very responsive ~250rwkw on 98.
I'm certainly keeping a close eye out for results on the new Garret series.
(But I promise I still love my EFR guys, don't hate me) :)
Without digging too deep the 7064 can be had with a T3 flange, I would just need to dig in to maps to see how it compares with the potato. All this is a little by the by anyway as I doubt the money will be there to throw a new snail at it this year, but you never know. I can see up to about $5K between it and back on track as it is so it is not really very likely to be changed this year, but I tend to plan these tings a long way ahead.
The RS is snappy enough on it that I gave up on closed loop control with the previous ECU (Old E11 Haltech) as it was impossible to dial out big boost spikes at high RPM. The new ECU just about has more tables for closed loop than the E11 did for everything it had.
https://gcg.com.au/petrol-performance/performance-4/turbochargers-borg-warner/borg-warner-efr7064-turbocharger-t3-v-band-detail
Edit: Whatever ends up on it next what I would really like to do though is get rid of the split adapter. Aside from anything else I have had constant issues with the tiny T25 nuts and studs undoing in use. At least it was easy to get a lock tab for the T3 setup.
Edited by Blue
3
Ah yep, I tend to forget about the 7064 for some reason. TBH wish I'd gone that direction at times to lose a little response for a better flowing rear (comes in 0.92 in T4 TS, instead of the 0.80 the 7163 comes in).
Again, hard to compare when I'm not sure just 'how' responsive your current setup is. What's the curve look like? When are you hitting max boost or torque?
The 0.80a/r EFR7163 hot side flows the same as the .83a/r T3 EFR7064 hotside, and the .85a/r EFR7163 flows the same as the .92 EFR7064.  That dirty old mixed-flow turbine isn't a terrible thing.
Wouldn't a 6758 be closer to a 2860 in terms of performance? Bear in mind RB20 not 25 with vct and the trimmings.
Edit: T25 though so not ideal.
Still you have a 56lb/min turbo like the 7064 or 60lb/min in 7163 trim, or a 35lb/min turbo in the 2860rs, bit of a difference. Not sure either of those two would quite match the low end of the 2860, though transient may be better?
I can live with dropping a little lower RPM performance, so long as I can also live with the potential extra maintenance cost of anti lag!
One issue I face no matter what is the range of housings with a T3 flange is pretty limited.
Dyno sheets from when the car was tuned, I would not want to loose too much at the low end or midrange. Bearing in mind that the car could easily make more at the same boost, given the total lack of engine protection on the old E11 I asked for and received a nice safe tune. Before and after on these sheets is a proper tune at 18PSI versus a very rough track tune at 13.
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
